smooth heel-toe downshift from 3rd to 2nd?
Results 1 to 15 of 19
This is a discussion on smooth heel-toe downshift from 3rd to 2nd? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Any tips on how to do a smooth heel-toe downshift from 3rd to 2nd? Situation would be for getting into ...
    Aug 2013
    Austin
    Any tips on how to do a smooth heel-toe downshift from 3rd to 2nd? Situation would be for getting into gear before an upcoming right turn. My WRX shudders when I release the clutch so not sure if I'm timing it right...
    What's the ideal mph/blip rpm to release? Do you pop the clutch or slip it a little?
    Thanks!
    Feb 2013
    Columbia SC
    there is no all around best rpm.. thats going to have to do with what speed your going when your shifting into that gear.. i personally use the two sides of my foot instead of the heel and toe, just how i learned to do it..... you gotta play with it to figure out , eventually your figure out by how fast your going, where it needs to be and then you wont need to barely slip it at all. youll be able to feel if its in the right place as soon as you start to let the clutch out...... practice makes permanent....
    2013 WRX sedan - MODS = pretty much every bolt on besides a bigger turbo.
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    hhhmmm interesting I've never even thought about it. I've been driving a stick for 38 years, just seems instinctive to me. But I'll have to look at my habits.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
            MainFrame's Avatar
    Austin, TX
    What works best for me in my car is to stab the gas pedal all the way to the floor and immediately release, basically the same with the clutch. My engine revs quicker than stock, so the faster I complete the gear change the smoother it happens. If I down shift practically as fast as possible it feels pretty dang smooth.
    Registered User frenziedcage's Avatar
    May 2012
    Colorado
    Rev match seems like the most reasonable way.
    Registered User wrx50's Avatar
    Jun 2012
    MA
    Rev match. Easiest and very effective
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    It just takes practice. It took me about 3 months of continuous practice to master heal-toeing with double-clutched downshifts. Now it's effortless.
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
    Jul 2013
    Silicon Valley
    Why are you double clutching andheel-toeing? Are you running an aftermarket transmission? The heel-toe should Rev-match you to allow a smooth, fast shift.
    Aug 2013
    Austin
    thanks for the tips so far! I get nervous letting out the clutch because of that shudder while still braking... Coasting then doing it right after the turn is no problem because I can add gas and smooth it out. It's tougher for me before the turn, esp if it's a downhill slope. I'll try stabbing and letting off faster
    Jul 2013
    Southern NH
    Braking and letting the clutch out at the same time is not a good idea...unless I misunderstand you ????
            MainFrame's Avatar
    Austin, TX
    Quote Originally Posted by freshwipe View Post
    If you're talking about entering a corner at high speed with the clutch pressed in, you're doing it wrong. Without the engine connected to the wheels you're not "in control" of the vehicle.. I would feel very uncomfortable driving like that.
    Quote Originally Posted by cogito View Post
    Not sure what you mean.. how else are you going to stay in gear, in the appropriate RPM range for your powerband, while diving into a corner? If the engine is in fact rev matched to the gear you are going into then letting the clutch out should feel perfectly smooth, and if you're needing to decelerate quickly you're going to need to be on the brakes.
    Jul 2013
    Southern NH
    He's getting shutter which tells me he's breaking and letting out the clutch with no throttle. You just can't break and let out the clutch, you need to rev match like you said ..make sense ??? I'm watching the Red Sox so I may be in coherent.
    Jul 2013
    Southern NH
    Plus that would be braking ... I'm incoherent ... lol.
    Aug 2013
    Austin
    sorry, thought it was understood that I'm blipping (rev matching -- or trying to) while braking...isn't that what heel-toe means?
    Just having trouble timing the release of the clutch to make it smooth. *this is only from 3rd to 2nd* in my '13 wrx. 5>4 and 4>3 is easier to do smooth
    Oct 2011
    Santa Ana, CA
    Quote Originally Posted by Zataks View Post
    Because race car!!!!!
    Its just more fun. Plus since the syncros aren't doing as much work the shifter seems to slide in much easier.
