Grinding shifting into 4th gear
Results 1 to 6 of 6
This is a discussion on Grinding shifting into 4th gear within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hey I have a 2007 wrx with 30k miles. I went stage 2 5k miles ago. So when I'm shifting ...
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    So when I'm shifting from 3rd to 4th at about 5-6k rpm I hear a loud grinding putting it into 4th. This happens happens when I have the clutch in moving between shifter gates. This only happens when I'm hard on the gas at high RPM.
    Do y'all know what could be doing this? I thought synchro but I don't think that makes sense
    Sent from my SCH-I545 using Tapatalk 2
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
    Registered User wrx frog's Avatar
    Jul 2013
    Wouldn't being hard on the gas and high rpm while shifting quickly be very hard in your syncros?
    Sent from my HTC-X710a using Tapatalk 2
    May 2007
    New Orleans
    This happens when the clutch is in. from my knowledge it would not be the synchro.... Does it engage when the clutch is in or out?
    STU 17
    WATCH THIS
    Jul 2013
    Having the clutch in or out has no effect on synchro gear operation. A quick google search is in order as there are websites that can explain this better. I would think its your shifting (as described above) is the cause of your grind. Does it grind when your not giving it the beans while shifting?
    May 2007
    New Orleans
    What part of the shifting would do that? Just doing it quickly? And OK so its probably the synchro? I figured if it was a bad synrcho it would happen at all speeds. Also I have a KB short shifter with all bushings.
    STU 17
    WATCH THIS
    Registered User cogito's Avatar
    Jul 2013
    Southern NH
    Sure sounds like a syncro to me. If it was all gears I would say get a new clutch.
    2013 WRX Dark Grey Hatch
    1974 Datsun 260z Stroker
