How to tell the difference from broken front axle and broken differential?
Results 1 to 7 of 7
This is a discussion on How to tell the difference from broken front axle and broken differential? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Loud clunk when driving. Doesn't matter if it is in gear or not. Does it every 3 feet or so. ...
    Sep 2012
    Pasadena, Maryland
    Loud clunk when driving. Doesn't matter if it is in gear or not. Does it every 3 feet or so. The car is pretty much undriveable.
    Bone stock 2008 WRX Hatchback.
    Have you had a look underneath?
    Sep 2012
    Pasadena, Maryland
    Everything looks fines under
    The axle is intact, with intact boots, and connected securely? It is not broken? The hub is intact? The splined connections to the gearbox and hub are both OK? The steering is intact?
    Sep 2012
    Pasadena, Maryland
    Yep yep yep
    Something intact isn't broken, so the intact axle isn't the issue.
    Registered User matsayz's Avatar
    Apr 2012
    Vegas
    Center diff! Stop driving it and get it towed on a flatbed to the dealer.
