clutch - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
This is a discussion on clutch within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I think the only thing youll damage is the flywheel. kind of like when you drive too long on low ...
    Aug 2012
    Tucson, AZ
    I think the only thing youll damage is the flywheel. kind of like when you drive too long on low brakes and you need new rotors instead of cutting them. but youre supposed to replace the flywheel with the clutch anyway
    Apr 2013
    Quote Originally Posted by nsibanez View Post
    yeah, im going to replace flywheel whens its time for a new clutch. now I need to figure out if I should pay my private mechanic 250 or shell out 660 to the dealership.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by rallybeast View Post
    For what? A clutch change at the dealer is $1400-$1600. Most private shops are $1200-$1400. Hell parts are more than $600.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  6. #19
    Aug 2012
    Tucson, AZ
    maybe do it yourself is 600, but its a laboring job. you're not going to get away with 660 when you need to drop the transmission let alone 250 regardless of where you go
  7. #20
            MainFrame's Avatar
    Austin, TX
    Typical "private" labor charges are around $300.. as others said, the clutch itself will be around $600.. depends on what parts you go with, but cheap clutches suck.
  8. #21
    Apr 2013
    Quote Originally Posted by 06wrx4me View Post
    the prices above are labor only. a stock clutch kit and flywheel will run me 750.
  9. #22
    Aug 2012
    Tucson, AZ
    you could also do an exedy oem replacement which I believe in around 300 minus the flywheel
