Alrighty. This was a bit odd. When I replaced the bushings for the diff mount with the new ones supplied with the TiC clunk killer kit everything went as planned. Too easily in fact. The studs came out of the rear diff housing without doubling up. Just a socket. That in its self is fine but on a 02 why studs? What mounts to them? There was no remains of locktite or anti seize inside the diff. Like a lot of things on my car they were quite frozen together, stud and nut. Can I simply replace them with a bolt and washer? The diff housing is aluminum so I don't want to accidently bottom out a hole or crack the cover from over torquing
