Just Installed Kartboy SS and Front/Rear Bushings...Grinding Noise Being Heard Now
Results 1 to 10 of 10
This is a discussion on Just Installed Kartboy SS and Front/Rear Bushings...Grinding Noise Being Heard Now within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hello everyone! First and foremost, let me tell you what I was working with: Completely stock 2012 WRB WRX Limited ...
    Registered User SubieDoo0531's Avatar
    Nov 2012
    New York
    Hello everyone!
    As the title of the thread states, I just installed a Kartboy short throw shifter and front/rear bushings this weekend. The install went fine - everything seemed to fit well. I noticed right away the difference the short throw makes with every gear change. I especially like the stiffness it it has with both front and rear bushings installed versus the factory setup.
    HOWEVER...
    Herein lies the problem. When I'm in any given gear past 3k RPMs and let off the gas to decelerate, I hear what can be described as a grinding-like noise coming from underneath the car. The noise is most noticeable in 1st, 2nd, and 3rd gears. It only occurs while letting off of the gas. I have the day off Wednesday, so I'm going to put it up on ramps again and check it out.
    But at the moment, I'm somewhat concerned as I don't want to destroy my baby. So I would greatly appreciate any help or advice anyone has to offer.
    Thanks in advance!
    Steve
    Registered User anpato's Avatar
    Jun 2012
    Mine does the same thing, in 2nd mostly.
    2013 SWP WRX Sedan
    Hillside, NJ
    Invidia Catless Downpipe, Custom Short Ram Intake, Self Tuned Using ECU Flash, Romraider and Tactrix
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Maybe an obvious question. But did you torque the heatshield back in place?
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
    Nov 2012
    New York
    Quote Originally Posted by rage-wrx View Post
    Nothing too serious, but I probably tightened it more than it had been from the factory. Do you think that could cause the issue?
    Aug 2010
    Yonkers/NYC
    Its possible. But just know that what you are experiencing is a pretty common issue with WRXs. And most have concluded that it is pretty normal.
    T0ny
    2011 WRX
    2012 FXT
    Nov 2012
    New York
    I appreciate your help. It just never happened before installing the short throw and bushings, so that's why I was initially concerned. But I'll take a look at the heatshield and try playing around with it and see if it makes a difference. Thanks again!
    Registered User ProZach626's Avatar
    Aug 2008
    Home of the blues, the Blues, and the real life blues.
    Sounds like I won't be getting shifter bushings..
    Jan 2012
    rubber bushings are used because they isolate noise and vibration. you've now replaced those soft rubber bushings with hard urethane which does the opposite and transmits noise and vibration. the sound and feeling of the gears is normal. you will get used to it.
    personally, a group-n transmission mount is the best investment you can make along with a short shifter. again though, you will get more noise and vibration but it doesn't mean something is wrong.
    Jun 2012
    last month thread but i've been driving my 3 week old WRX and noticed the noise the OP described and i'm completely stock, it seems that the sound is normal and the OP noticed it more because of the aftermarket bushings, for this reason i'm planning to use an SPT/STI rear bushing and the kartboy front bushings when I do my shifter upgrades that seems to keep noise lower from what i've read.
    Mar 2013
    Quote Originally Posted by crows View Post
    I also noticed this noise when stock. Than I installed positive shift/pitchstop/shifter bushings/group n/cobb short throw. and the noise and definitely gotten more noticeable. It sounds terrible to me. I am going to get under the car today and make sure everything is torqued to spec.
