Kartboy Short throw shifter, still have play?
Results 1 to 9 of 9
This is a discussion on Kartboy Short throw shifter, still have play? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; ok after doing the karboy short throw shifter and all the bushings (front and rear) i still have play when ...
    Apr 2013
    ok after doing the karboy short throw shifter and all the bushings (front and rear) i still have play when its in 3rd and 4th gear. (meaning i can move the knob about 3/4 inch freely while its in gear..... other than that i love it... anyone else have this problem?
    Registered User maus's Avatar
    Mar 2012
    Palm Beach, FL
    It's normal. Get a Group N Trans Mount. It reduces a lot of slop.
    2012 DGM 5 DOOR WRX
    Mods: Stage 2+
    "I live my life a twelve year old at a time. For those ten seconds or less, I'm free."
    Official ClubWRX Creeper
    Registered User MercRising's Avatar
    Mar 2012
    Littleton
    Group N trans mount and some front crossmember bushings (aka positive shift kit). That and what you've already done should really tighten up the whole feel of the shifting quite nicely. Very easy installs too.
    GL with it.
    May 2010
    Pittsburgh, PA
    Some engine mounts help as well, FWIW. I'd plan on doing them with a front sway bar or something along those lines. I went with GroupN, as most people do. I'd probably go to a harder bushing next time, personally.
    2011 STi Build Log
    Registered User SomeGoalie's Avatar
    Jan 2013
    Cleveland
    When you say you did all bushings, were you talking about just the front and rear shift bushings?
    If you haven't already, I'd look into doing the shift linkage bushings.
    http://www.rallysportdirect.com/Turn...-STI-2006-2011
    These are designed to remove side to side play. You can also do the shift pivot bushing that goes in the shift lever if you haven't already.
    Apr 2013
    Correct I did front and back bushings
    Jan 2013
    Cleveland
    Quote Originally Posted by 2013WRX_USMC View Post
    From what I've read, the linkage bushings make the biggest difference in side to side play.
    Jan 2012
    Quote Originally Posted by SomeGoalie View Post
    Turn In Concepts Shift Linkage Bushings Subaru WRX / STI 2006-2013 SLB-06-SUB at RallySportDirect.com
    Have any of you guys actually ordered these? They are the biggest waste. They are just plastic/urethane bushings and allow just as much flex as the stockers which are also plastic.
    The slight side to side play is simply part of the inherint design of a remote mount shifter.
    Registered User younoleit's Avatar
    May 2012
    I have all 4 sets of bushings installed. Front/Rear/Shifter Linkage/Pivot. It is much improved, but there is some play, most notably 1,3,5. You may notice there are all on the "Top" of the WRX shift pattern. I have put in many hours of thought into why this is. My old Mazda was also a 5 speed with a STS, much like my WRX, and it also had play IN THOSE SAME GEARS! I think it has something do with being a 5 speed and the design of the transmission itself. It would be awesome if someone with the answers could speak up.
