STi Short throw - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
This is a discussion on STi Short throw within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Thanks all, i chose against it esp. when the labor rate went up to 150.00. I'll use the money for ...
    Registered User cmayba's Avatar
    Feb 2013
    Upstate NY
    Thanks all, i chose against it esp. when the labor rate went up to 150.00. I'll use the money for a strut tower brace.
    Quote Originally Posted by cmayba
    Waste of $$. Unless you're getting a hatch, and I'm not even sure the newer models benefit from a rear strut brace like '02-'07 did. Still, you'd want something like the Whiteline quick-release brace (if they offer that for '08+) so if you needed the cargo room, it was easy to dismantle.
    Resident Tuner @ WTF Tuning
    Registered User R_Wrx21's Avatar
    Apr 2013
    Atlanta, ga
    Not off topic he may wanna check it out its a thread dealing with short throw if I was asking about a borla exhaust that's off topic but when I ask about something dealing with the topic I'm pretty sure it's not off topic. It's asking specifics. He asked about spt I asked about twm. Pay attention same topic
  6. #19
    Apr 2013
    Atlanta, ga
    Btw if google was helpful I wouldn't have asked.
  7. #20
    Feb 2013
    Upstate NY
    I'm going to save the cash for a Perrin front strut tower brace....I knew I joined this forum for a reason. Once again thanks!
  8. #21
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by R_Wrx21 View Post
    The OP was considering adding on the SPT option while it was at port. Normally the debate between the SPT shifter and an aftermarket shifter doesn't require reviews of every aftermarket shifter. I didn't mean to be a jerk, but the first time you asked about it, you didn't get any response because it was nested in a thread it shouldn't be.
    Little testy, brah?
    Let me google that for you
    ...I believe the second link down should help you out =). Most posts that have "TWM shifter" in the title from any forum with "wrx" or "sti" in the URL will probably help you out. They will give you more information about what you are looking for than this thread does.
    Quote Originally Posted by cmayba View Post
    Save the cash as Matt said. The strut towers are quite close to the firewall in our cars. It's mostly bling with a bit of added weight. Some claim the brace helps reduce dashboard rattles... I'd just use felt tape personally. There are plenty of places to put the cash. Give turninconcepts a ring. They'll hook you up with a shift kit that is way better (and cheaper) than the SPT by itself
    2011 STi Build Log
