Results 1 to 2 of 2
This is a discussion on can not find a throwout bearing to fit my transmission lookes like it has a sleeve within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I have a 06 impreza 2.5i na it has 5 speed trans my old throwout bearing went out so I ...
    Mar 2013
    alexandria la
    I have a 06 impreza 2.5i na it has 5 speed trans my old throwout bearing went out so I bought a xtd stage 2 clutch throwout bearing and pressure plate well everything works except the throwout bearing so I tried oem well it also doesn't fit the shaft it looks like it has a sleeve on it any ideals????
    Registered User sjcurtis's Avatar
    Sep 2010
    Selma, Alabama
    You might have got a STi clutch kit by mistake. Do you have a part number from your order?
