advice on launching? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
This is a discussion on advice on launching? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Originally Posted by EJ257 A clutch is cheaper to replace than a transmission. If one is going to get the ...
    Palmyra, NJ
    A clutch is cheaper to replace than a transmission. If one is going to get the abuse, you can infer my choice...
    That sounded very SD-GRish.
    Spiros is wise. I said it in the proper Spiros voice, at least the one we all believe is his...
    Resident Tuner @ WTF Tuning
    Dec 2011
    Pottstown PA
    Some say that his blood is pure unicorn jizz, and that the sneezes full recirc, all we knows is, hes called the Spiros.
    Marky Mark
    My bugeye build
    MinoskePhotography
  6. #19
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Quote Originally Posted by Ruh Roh View Post
    I heard he once knocked out a horse with a single punch, and you can hear his thoughts anywhere in the world by tuning into 88.4 FM...
  7. #20
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    I'm so doing a user title edit...
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
  8. #21
    Dec 2011
    Pottstown PA
    Marky Mark
    My bugeye build
    MinoskePhotography
  9. #22
    Quote Originally Posted by RayfieldsWRX
    With how often he uses his phone on the forum, who knows when he'll actually realize it
  10. #23
    Registered User santorex's Avatar
    Sep 2012
    hey i was curious too on how to launch these things. i know people tell you not too, but i think it's a good skill to have even if you don't do it often at all. i emailed this around a while ago which was taken from another post. i can't seem to find the post. i'm not trying to steal anything, but here it is...
    "There are two things you need to accomplish to get a good launch in the wrx.
    You need to launch under some boost,
    and you need to control the load on the engine so it stays near max torque rpm for the first few feet without banging the clutch and shock loading the drive train.
    There are several variations on the theme and each person will discribe it slightly differently but you want to engage the clutch quickly and smoothly so it slips just a bit with out just side stepping the clutch, or frying the clutch by holding it at partial engagement. The newer 2003 cars have a flow limit valve in the clutch line so you cannot just let up on the clutch and break things. It slows down the engagement just a bit. On the 2002's you'll have to do that yourself.
    One of the top WRX drag racers in the country describes the technique where you stage, and then let the clutch out a bit until you can tell it is just ready to engage (the friction point) is just a fraction of an inch away.
    Hold at a moderate fast rpm (everyone picks a slightly different number) I use about 3000 3500 rpm.
    Now comes the key to launching under boost.
    You can only build boost under no load conditions when the engine is accelerating at WOT .
    Just as the second yellow comes on, stomp the throttle to the floor from your stage rpm, the engine will take about a second to rev to red line. There is only .500 seconds between each of the yellow lights.
    Watch the tach and as the rpm swings by 5000-5500 rpm let up on the clutch quickly.
    (you can't wait for the green light you have to start leaving on the last yellow)
    Since you prepositioned the clutch right at the friction point there will be very little clutch motion, or shock, your engine will be very close to 5500 rpm when the clutch engages and under some boost because you floored the throttle a fraction of a second earlier. If you get all that coordinated you should have enough torque and energy stored in the flywheel so the engine does not bog.
    Hang on !!! you will be accelerating at over 1 G and hit red line in low in about 1.5 seconds.
    Be ready to shift !!!!!
    The biggest time loss that keeps folks at 2.x seconds is a slow shift, you have to shift quickly to get back under power in second gear before you complete the first 60'.
    Shift quickly and firmly but NOT VIOLENTLY !!! your not trying to break anything just be quick.
    I tell folks to hold the shifter in their fingers not to grab it like a club, this gives you more feel and makes you less inclined to try to rip the shift knob off the console.
    If you get it right its quite a ride."
  11. #24
    Jan 2013
    Denver
    Quote Originally Posted by santorex View Post
    sounds good. might try a few more times over the next few days. I don't want to destroy anything but if I do its all in the learning lessons
  12. #25
    Jan 2013
    Denver
    so I'm guessing launch control would be for NOOBS haha
  13. #26
    Oct 2002
    The Old Folks Home
    I'm wondering if you guys that regularly launch your cars are honest about that when you eventually sell it.
    --Ray
  14. #27
    Jan 2013
    Denver
    I know I wouldn't haha
  15. #28
    Palmyra, NJ
    Quote Originally Posted by xblitz151 View Post
  16. #29
    Registered User thegamer1587's Avatar
    Oct 2012
    Western Pa
    Glad I bought a new one!
  17. #30
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    This is why I am always skeptical when I read "adult owned, never abused" in used car ads
