This is a discussion on 5MT Shifter Bushing Install Frustration - Cobb Bushings are junk within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; So the rear bushing eventually went in... Its crossed for sure but I ran it down in anger. Its not ...
So the rear bushing eventually went in... Its crossed for sure but I ran it down in anger. Its not moving anymore.
When I do the front bushing I want to do the trans mount so I will most likely wait. I did however go buy a creeper... I had enough crawling around on my back and my jack doesnt jack the car very high so the stands were not up high... Argh what a frustrating weekend
2012 WRX Hatchback ISM - Base Model - STI STS, SPT Boost Gauge, AEM Intake, TP Stage 1 Tune, red illumination kit, cobb shift knob, 20% tint - currently on stock wheels wrapped in Pirelli Winter Carving Edge Tires
Some cooltidbits to come...
-Noah
2009 Spark Silver Metallic Sedan - Stage 2+
Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
the install was a complete PITA for me as well. i used ramps. but as others pointed out, you just have to fiddle with it.
another post on here had a guy who stripped the thread going to town on it. it's definatley a pain in the @$$
if i had to do it again, would have waited until i could use a lift.
2012 WRX Premium Hatch, Stage 2
Ice Silver Metal
I'm wondering if they carried over the design from the GD cars, and there's a small dimension change between the two generations or something. I installed the rear bushing on my bugeye, and the hardest part was getting the shifter linkage back into the rear bushing. I didn't have any particular issue with the bolts.
That said, I also had the downpipe removed at the time, which at least on bugeyes gives you a LOT more clearance around the shifter linkage to work.
Isaac -- 2003 WRX sedan Stg II
He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
