Results 1 to 7 of 7
This is a discussion on What clutch should I use? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Hello, I've got a 2002 wrx sedan and I've gotten it up to 285hp/271tq. My clutch is starting to slip ...
    Dec 2012
    Unhappy What clutch should I use?
    Hello, I've got a 2002 wrx sedan and I've gotten it up to 285hp/271tq. My clutch is starting to slip really bad now, its been slipping for a while and now its time for a new one finally!! what clutch would you recommend for me? i would like to stay under $300 and the tranny is stock. is that to much hp for the stock tranny? thanks!!
    $300 or less isn't going to happen.
    Exedy StageI or OE replacement
    New OE flywheel
    History will tell whether your gearbox will hold; I can't. It's up to you to some extent.
    If your clutch only now started slipping, after ten years, it's a good clutch. I'd replace it with OEM or the OEM Exedy. Only if it were to fail again and soon would I look for a different clutch (notice I didn't say "upgraded," I said "different" and I believe I did so for good reason).
    Mt. Laurel, NJ
    As Matt (EJ) says, Exedy OEM replacement would be your best bet.
    When you're pushing a fair amount of power, which is cheaper and easier to replace? A clutch or a whole transmission?
    Dec 2012
    Ok, thanks for the help!
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Exedy OEM or stage 1
    OEM flywheel.
    Click the link in my sig to get an idea of what is involved. There will be a few more steps since your car is a 2.0l.
    Apr 2007
    8000' up in Colorado
    Lots of good advice here (that I hope you're going to follow) to stick with OEM/Exedy...
    Scott
