Results 1 to 12 of 12
This is a discussion on Noisy driveline within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I have been noticing lately that my WRX drive line is noisy. When I let off the accelerator I hear ...
    Jun 2012
    Wilmington NC
    Noisy driveline
    I have been noticing lately that my WRX drive line is noisy. When I let off the accelerator I hear some whining. I have read that this is normal in these cars but I have never really noticed it before. Also when i'm shifting I can hear a noise that seems like the clutch engaging/disengaging. It's a slight clunk but I don't hear it if I let the clutch out slow enough. Also I never hear it starting from a stop. It's just from 1-2-3 and sometimes 4. (It's not the rear differential.)
    UPDATE:
    I have a noise that's a little clunk or tap sound when I let out the clutch. It sounds like the clutch engaging if that makes sense. If I have my car in neutral and slowly let out the clutch I can't hear it. It only happens when you let the clutch out modestly fast. If the car is not running it does not make the sound. It only happens when the engine is running? It sound like its coming from the transmission area. It's not the rear end clunking because it happens when the car is just sitting stationary.
    Thanks,
    Zach
    Jun 2012
    Wilmington NC
    Anyone?
    Oct 2005
    Late Devonian
    The whine is almost certainly normal. It gets a lot louder once you start replacing the driveline bushings.
    Usually the clunking is the rear differential shifting or the carrier bearing. If it is really coming from the transmission area you should check it out - check out the motor mounts transmission mount etc.. It could be as simple as the DP hitting the trans or something. If you have a warranty take it in, or otherwise poke around and see if you can find anything.
    Jun 2012
    Wilmington NC
    If I'm idling in neutral and I push the clutch in and out I can hear the clunk, but If I shut the car off and do the same thing I cannot hear the clunk?
    Oct 2005
    Late Devonian
    Hmmm - I don't know. That is the kind of thing I would go have checked out myself.
    zax
    zax is offline
    Tony Vargis zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Subaru transmissions are notoriously loud. Mine whines more than a spoiled child.
    With the introduction of a stiffer transmission mount, cross-member bushings, shifter bushings, and pitch stop, the noise level increased exponentially. It's part of the charm
    Facebook me here
    Jun 2012
    Wilmington NC
    Jun 2012
    Wilmington NC
    Quote Originally Posted by zach1288 View Post
    Here is a video sorry for the quality. You can hear the sound the best when the camera is near the sideskirt/under the car:
    http://youtu.be/40wuIr1HNIo
    Jan 2013
    Oregon Coast
    I just purchased my 2011 wrx and as I was driving to work today half way through my trip I noticed a strange whine that comes from the front, and is only happening while accelerating at higher RPM's any ideas what this could be?
    Registered User EndlessSea's Avatar
    Nov 2012
    Las Vegas
    its normal. my 2013 makes the same noises. remember. your 26k wrx or 36k sti is still based on a 16k impreza. its not gonna be as smooth or quiet as a bmw
    Registered User mcdbrendan's Avatar
    Dec 2011
    Boulder, CO
    Quote Originally Posted by EndlessSea View Post
    Call me crazy, but I prefer the louder noises from the transmission.
    Mt. Laurel, NJ
    Yeah with Subarus...if your driveline is being quiet, THEN you have a cause to be concerned.
