Results 1 to 9 of 9
This is a discussion on Help... I have clutch issues with a new build. within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Help I’m lost at what the problem could be... So two months ago I tossed a rod bearing in my ...
    Registered User Allroy1967's Avatar
    Feb 2011
    SLC , UT
    So two months ago I tossed a rod bearing in my car, I pulled the motor and had it rebuilt. I put the motor back together and went to start it and no compression. I pulled the motor back out tore it back apart and found out that the person that rebuilt the heads forgot to grind down the valves so they were hanging open F**#&$...
    I then put the motor back together for the second time started it and it fired right up and sounds amazing.
    I notice that my clutch pedal is felling soft and just having put a new clutch in it I know that it shouldn’t be. I proceed to bleed the clutch and get some little air bubbles nothing major. After bleeding it and now having a good feeling clutch pedal I go to take it on a test drive. Car starts up fine... now my clutch is no existent again.
    I bleed until all of the fluid is changed out and the pedal feels like it should... start the car no clutch
    I have changed the master, the slave, and the lines (all at different times)out with new and bled it out each time.. I have no idea what the problem could be please help.
    02 Bugeye
    98 Taco SAS RockRig *Just Sold*
    People in America can sleep safely tonight…Because the US Army is on point.
    Wanna-be in the Bugeye Mafia but cant get a #
    I'd suspect yet more air, potentially in the slave. The alternative is a leak, but since you cannot find one, we're left with air. There is a third, remote possibility, that you have a faulty membrane in a new master or slave, but that's very unlikely in my view. I hate to say it but you may have to keep bleeding, with an eye for air downstream toward the slave (I think...).
    Apr 2007
    8000' up in Colorado
    Yeah sounds like air in the system to me too.
    Scott
    Feb 2011
    SLC , UT
    I have gone through the system quite a few times... is there a trick to this system that you have learned over the years that might help?
    02 Bugeye
    Registered User v6mx6ls36's Avatar
    Jan 2009
    El Paso Texas
    Clutch may have been been put in backwards . I did it to mine when I removed and rebuilt my eng . The disc will install backwards . And u will think its a bleed issue as I thought with mine . Bleed and bleed and nothing . Finally came to realize the disc was in the wrong way . Flipped the clutch disc and Valhalla clutch works .
    The Kind Administrator. Watch out for the others Trainrex's Avatar
    May 2003
    Quote Originally Posted by v6mx6ls36 View Post
    I'm with him. Disc in backwards or fork not seated correctly in the throwout bearing.
    I did not know that was possible, thanks!
    Jan 2009
    El Paso Texas
    When your looking at the clutch up against the eng the bulging part sticks out away from the eng . Not fitting into the flywheel if that makes any sense .
    May 2003
    Both are, and I've done both
