Results 1 to 5 of 5
This is a discussion on downshifted instead of upshifting within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; hey guys , i wasnt paying attention tonight and i downshifted from 3 into 2nd twice! instead of 4th i ...
    Registered User Tom-Wrx's Avatar
    Oct 2011
    Westchester
    i have a 2002 wrx tranny that is in good condition.
    it was for less then a second like i let it out the revs shot up and i quickly pushed on the clutch .
    Shifting Day n Night in my RedRex
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    honestly... probably fine. It's really difficult to get into gear from 3rd to second if you're at a high RPM. So I'm guessing you were shifting at like 5k or lower, right?
    At 5500k in 3rd, you're at redline in 2nd (ish)... which is not enough to kill the engine from over speeding. And if you did kill the engine... it probably would've gone out quicker than you would've had time to drive home and post this.
    May 2010
    Pittsburgh, PA
    Or at least you woulda known something was up.
    Happens. I mess up shifts time to time. I'm more notorious for hitting third instead of fifth. Normally it's on the highway. I generally don't force the lever in at all, but sometimes it happens. I notice quite quickly when I let the clutch out and I see the passengers head hit the dash =P.
    The worst little mess ups are when you think you popped it into neutral in a parking lot or whatnot... drop the clutch.... and find out you aren't in neutral. That's always a fun one.
    2011 STi Build Log
    Dec 2011
    Pottstown PA
    ^^ ive went from 4th to third once, scared myself lol
    Mt. Laurel, NJ
    It will blow up next time you do it. It only has a 3 misshift limit on the 5spd transmissions. So be careful.
    ...I kid I kid...Just be careful. You're probably fine.
