Results 1 to 15 of 16
This is a discussion on 2012 WRX Transmissin getting notchier as I put on the miles within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I just wanted to know if this was normal behavior or not because I could have sworn the car shifted ...
    Registered User gunz4me's Avatar
    Dec 2011
    Louisiana
    I just wanted to know if this was normal behavior or not because I could have sworn the car shifted smoother when new and now the transmission feels super notchy compared to day 1. I wonder if it is time to look into shifters and bushings?
    Wants to Sell His Honyota Civilander..Any Takers? BigDaddyRex's Avatar
    Jan 2011
    Central NJ
    Mine came with the SPT Short Throw Shifter, and my experience is the opposite. I've found that over the last 18 months the units has become much smoother than it was. Maybe its just the STS.
    - Chris
    2011 WRX DGM (The Fastest Color) 5DR
    Cobb AP OTS Stage 1 93, STS (the dream comes true ...)
    Dec 2011
    Louisiana
    I may end up with the short throw shifter next. Since SOA is so picky about warranty, I'd probably stick with SPT parts for the time being. OTOH, if I go another route, I am certain this isn't the last time I will void a warranty on something.
    Registered User Jdmluvr's Avatar
    Apr 2012
    Thornton
    I was thinking the same thing on mine. I have 10k miles now and it seems like its a hair on the sticky side.
    Aug 2012
    Re: 2012 WRX Transmissin getting notchier as I put on the miles
    Maybe you're just getting used to it, and notice things you didnt at first. My 2010 has 17k and it doesn't seem as smooth. And I'm very easy on the clutch and transmission.
    Same goes for the power. Coming from a 99 Ford Taurus, my WRX seemed lightning fast when I test drove it. Now that I drive it every day, it seems slower. But in reality it's all in my mind. Just a thought.
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    if you do a lot of stop and go driving, and are aound 15k miles, ou may want to try changing the tranny oil.
    that helped me out.
    i also have stiffer shifter bushings.
    The Fruit mangostick's Avatar
    Oct 2009
    the ghettooooo
    subaru super S ftw
    change the fluid.. it'll butter up nicely. These transaxles are VERY picky about what fluid they like. So far I've found personally and through lots of reading that super S is the sure shot way to go. Its also OEM approved and provided so no warranty issues.
    OBP 2010 5dr *traded*
    SWP 2013 FRS
    SUCH IS MANGO!
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by BigDaddyRex View Post
    The STS is just a shorter linkage under the car that moves the pivot point of the lever a bit. It's a good idea, but shouldn't have a drastic effect on feeling. For what its worth, you can combine the shorter linkage with a short throw lever for an extra reduction in throw =).
    I haven't noticed much of a change over time personally.
    Quote Originally Posted by gunz4me View Post
    With the above being said, I would pick up the kartboy bushings over anything. A shorter lever won't help shifting feel much (if at all). However, there are several important bushings between the shift lever and the transmission. I would doubt SOA would give you much trouble about them (provided you don't mess stuff up when installing them), and they are a fantastic mod. Adding in a short throw lever makes for a nice touch at that point since it will already be out.
    2011 STi Build Log
    Dec 2011
    Louisiana
    Quote Originally Posted by tesla317 View Post
    What messed me up was driving a friend's 370z. His car shifts much smoother than mine does and I think that is what made me realize how bad the stock shifter actually is. Remember, I came from a 2006 Mustang GT and it had a horrible shifter.
    I had that same experience with the Mehstang when I got it. At first, I was scared of the power coming from a totaled 2007 6MT Accord. By the time I got rid of the Mehstang, I felt it was really slow and super unpredictable when it came to what the rear end would do in any given situation other than a straight line. While some complain about the WRX, I find that I can predict what it will do in any given situation compared to the Mehstang.
    Apr 2012
    I came from a Honda Fit. I was scared ****less driving it home.... In the night...
    Oct 2009
    the ghettooooo
    We've been telling this to the mustang lovers that show up here pretty regularly lately. I've been around big hp straight axle cars for a long long time.. and every time I mention they handle like a lowered pickup some stang owner pipes up and disagree's. Thanks for seeing what I've seen and not fearing mentioning it.
    SWP 2013 FRS
    SUCH IS MANGO!
    Aug 2012
    Bristol, CT
    Quote Originally Posted by mangostick View Post
    subaru super S ftw
    so is this the same thing as changing the diff fluid? or is the trans and diff two different gear fluids that need to be changed. i want to be able to shift nice and smooth regardless of how many miles are on the car. during cold starts its harder to shift but as it warms up its easier at low rpms. that's why i think its a fluid fix and hopefully not shift linkages and forks. but regardless of the fluid beign warm at high rpm it takes it a few seconds before it wants to go into gear.
    just change diff fluid? or flush out the clutch fluid? or what?
    Registered User Jonny1106's Avatar
    May 2012
    Albuquerque, New Mexico
    New kartboy bushings should fix problem. Your bushings are probably just wearing
    Sent from my Galaxy Nexus using Tapatalk 2
    2012 SWP 5door Premium!!!
    Jan 2011
    TX, NY
    Quote Originally Posted by nsibanez View Post
    the transmission fluid and rear diff are two different things. but they both use the same extra-s oil. Personally, i just do a change, and maybe pour a little bit of clean oil through before i put the plug back. but that's it.
    Aug 2012
    Bristol, CT
    Well I know the rear diff is different. It' just to transfer power to the rear wheels. But the tranny and front diff, or tcase, are the same with our subarus like it is with some toyotas?
