You won't break an STI tranny.
This is a discussion on swapping chevy tranny into my 03 wrx within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; T56 would handle it. The guy won't build the bell housing for a t56. I'm waiting on a reply about ...
T56 would handle it. The guy won't build the bell housing for a t56. I'm waiting on a reply about the t5.
If not. I'm going with the w58.
Either way, this is how I see it, say I spend 4k doing this swap, and a Sti swap is 4k, when I break a rwd tranny, I can get the parts or a new tranny for pretty cheap and they are readily avaiable. I break a Sti tranny, I have to wait until I can find a Sti tranny and then drop another 2k and hope its not broken.
Hawk-Eye Alliance #001
The Tranny Fluid Thread | HAWK EYEs | 06 Clutch change | 06 timing belt | DIY wooden wheel stands | DIY Alignment
06 WRX TR
I believe Bobby and Jen, the wrx you talk about in your OP, had a turbo 400 with an adapter plate made by Advance Adapters. That should work for your T56. You could always call PRE racing and see who their contact was and what they paid for the adapter plate.
Oh and it is possible to break a T56 from out of anything but the Viper, but the T56 is stronger than the T5.
06 WRX TR
When I looked up Sti trannys, I found 375 to 400. A wrx 5 speed is around 300.
I know plenty of people with 550-700whp (some over 550wtq) that race practically every week on the STi transmission without problems. 9 and 10 second passes all day long on the six speed.. occasionally they will snap a rear axle, but that's about it.
06 WRX TR
Sounds like you guys are misinformed.
I live over a mile above sea level. A 10 secon pass down where your at is a 12 second pass where I race at.
There's a black Sti tuned by metro performance in Denver who runs 10.7's all day long, but he has destroyed his gears do he has a upgraded gears to prevent it.
So the Sti is not bullet proof. It breaks with 500whp. So I'm taking my chances with the rwd conversion
Do you know how hard it is to make 500whp on an ej25? You are talking a giant turbo, FMIC, fully built block, methanol injection, very large fuel system with surge tank. I'd be surprised if you could do it for less than $7000. So if you are gonna drop $7k on making the motor fast, why are you sweating $2200 for a built tranny?
You do realize how hard its gonna be to get past mid 11.'s with RWD right? Your 60' is gonna go from 1.7sec on street tires with awd to 2.0-2.2 sec with slicks and rwd.
Still would be cool.
06 WRX TR
Umm, sounds like you're misinformed. If that car is a 10.7 second car way above sea level (just like here in El Paso) it is likely a what? 9 second car at sea level? And this because why? Oh, it's because the horsepower rating is higher at a lower altitude. Just saying, since your logic is fuzzy here.
Hawkeye Alliance #1050
Build Thread
http://i1108.photobucket.com/albums/..._Signature.jpg
Always dirty, never scurred......
A 10 second pass at sea level is not a 12 second pass at bandimere.
I'm going to agree with these guys that the rwd tranny would be awesome... If you buit it. But if you don't... It'll be a time bomb.
What size tires would you run in the rear? If they're just 245s or less... Then the wheel spin would make up for the weaker trans, because you wouldn't be able to grip and stress the gears like an awd can.
Right, you're at altitude, so the same same car with the same mods makes less power where you are and puts less strain on the transmission. I don't know how misinformed I can be about cars that I've watched being dynoed and watched on the track. The "mexico STi" put down 709WHP on the lowest reading dyno I've seen (baseline for stock STi is 205whp). He launches with aggressive anti-lag engaged and so far hasn't had any issues with the STi transmission. I realize that car at your altitude won't make as much power, but that doesn't mean it will break the transmission because of it.
Mexico runs - YouTube
I'm not saying it isn't possible to break the six speed, but if you know how to drive and you're running drag radials there's no reason you should need anything else unless you're well over 550wtq.
