Exedi organic stage 1 & Streetlite flywheel
Results 1 to 3 of 3
This is a discussion on Exedi organic stage 1 & Streetlite flywheel within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; So this set up was installed this Sunday, I drive and and when I shift from 1st to 2nd I ...
    Registered User Ervz's Avatar
    Jul 2012
    Las Vegas
    So this set up was installed this Sunday, I drive and and when I shift from 1st to 2nd I hear a grinding/rattling noise. When decelerating, once it drops to about 2000 RPM the noise is more predominant like I said when coasting. Did anyone else experience this type of situation before?!
            MainFrame's Avatar
    Austin, TX
    Did you replace (or inspect) the pilot and throw out bearings while you were in there?
    Jul 2012
    Las Vegas
    Yes I had a failure on the release bearing. I installed new pilot and release bearing along with pressure plate and clutch disc and a new flywheel
