Results 1 to 15 of 17
This is a discussion on Does the WRX have a limited slip differential? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; What is the differential setup on the WRX please? Limited slip in the rear? Thanks....
    Aug 2012
    If it is a WRX and not an STi variant it has open front and middle diffs. It will have a limited slip rear if it is an earlier WRX, but not if it a later WRX.
    Aug 2012
    I should have clarified WRX only. When did Subaru stop putting in limited slip for the rear year wise?
    I believe in 2008?
    2.0L snail power... Rambo's Avatar
    Oct 2010
    Korea/Japan/Taiwan/USA
    ^^correct.
    Isaac -- 2003 WRX sedan Stg II
    He who shall be last, shall be sideways and smiling... - Jeremy Clarkson
    zax
    zax is offline
    Taco Boy zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    Re: Does the WRX have a limited slip differential?
    Interesting. I would classify the viscous center coupling as "limited slip."
    Sent from my DROID BIONIC using Tapatalk 2
    Facebook me here
    I think you are right, because if it were anywhere else I'd not have considered it open. You're right.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Not entirely true.... The 4EAT (auto transmissions) use a torsen (torque sensing) planetary gear center differential, which apparently can also be locked by a solenoid from the transmission controller
    I think those can be opened by pulling a fuse?
    Nov 2006
    Denver Metro Area
    It sounds like it... and open it's a 45/55 tq split apparently
    (sorry... edited your post instead of replying)
    zax
    zax is offline
    Nov 2008
    FALSE!
    Not really, just wanted to contradict you
    Facebook me here
    zax
    zax is offline
    Nov 2008
    I'm confused here gents. To me, an "open" diff insinuates a simple pin and ring mechanism that distributes torque to either of two output shafts from a single input shaft. To add a limited slip mechanism to a differential suggests the addition of any device that disallows (or resists) a large torque bias between either output shaft (keeps torque evenly distributed). This can be accomplished with a viscous coupling, Torsen or any other torque sensing mechanical mechanism, clutch-type, Detroit locker, or any other exotic mechanism. Kevin you suggested the center diff on the 4EAT is a Torsen type. This is a mechanical locking mechanism that can evenly distribute torque in accordance to the torque bias ratio. If SD is indeed correct and the center LSD can be disabled with the pull of a fuse, I would suggest that the center LSD is a clutch type LSD similar to the DCCD. The planetary gearset is simply to achieve the uneven torque distribution under normal driving. FWIW the 5mt doesn't have a planetary gearset since the bias is 50/50 during normal operation.
    Facebook me here
    Jan 2012
    Philly Area
    I used to think I understood differentials. Clearly I need to go read some more articles.
    - William
    Nov 2006
    Denver Metro Area
    I'll have to look into it again, but I believe the 4EAT uses a MPT (multi plate transfer) clutch as well as the planetary torsen center, and the vlsd in the rear. But I believe that the front is open. I cannot remember off the top of my noggin though
    Nov 2006
    Denver Metro Area
    Just looked it up. Apparently the 4EAT is an Active AWD which uses an open front, planetary center at a 45/55 split, and a MPT in the tailshaft with a VLSD in the rear.
    Something else cool I found out... the 4EAT automatically shifts to 3rd gear during hard stops (ie ABS engagement) to prevent engine braking which causes unpredictability
