If you're replacing the clutch, you should be replacing the flywheel as well
This is a discussion on Replacing clutch. Fllywheel too? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; I am replacing the clutch in my 02 wagon as it is slipping occasionally. How do I know if the ...
I am replacing the clutch in my 02 wagon as it is slipping occasionally. How do I know if the flywheel should be replaced as well? The car has 150K + miles.
-mx
Any recommendations on which flywheel? I am assuming oem.
OE or ACT StreetLite. Read up on the pros/cons of a LWFW and choose accordingly
Or just take the flywheel to a machine shop and get it resurfaced for abour $40-60
Subaru specifically recommends against resurfacing of the flywheel.Originally Posted by sjcurtis
If it shows coloration indicating hot spotting, I would veer away from having it resurfaced.. although if it looks fine then you could get away with simply resurfacing it (I would get it balanced as well).
If you're wanting to go light, do not get anything lighter than the ACT StreetLite. At 13.9lbs it's just heavy enough not to cause problems.
I really don't want to compromise the reliability of the car. I'm inclined to go OEM. I haven't done any mods to it.
Probably a wise choice.
I went OEM on the flywheel, just replaced the clutch on friday. After doing a ton of research, it seemed almost every person with the ACT streelite or Exedy fw502, had bad deceleration clutch noise that I personally couldn't live with.
Replaced the Clutch in my 06 WRX: A reflection more than a DIY
Hawk-Eye Alliance #001
The Tranny Fluid Thread | HAWK EYEs | 06 Clutch change | 06 timing belt | DIY wooden wheel stands | DIY Alignment
06 WRX TR
