Results 1 to 15 of 20
This is a discussion on Weird clutch noise at startup. within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; When starting my car up I'm getting a weird clutch noise. It only happens when I push in the pedal ...
    Registered User Rallye_Ghost's Avatar
    Sep 2011
    Roanoke, Va.
    When starting my car up I'm getting a weird clutch noise. It only happens when I push in the pedal and only when the engine is cold. It goes away after the engine warms up. It sounds like a belt squeeling when I push in the pedal. Once the engine gets warmed up there is never a noise and I don't notice any problems with the clutch other than the described one. Any ideas on what it could be? I have a 2011 WRX hatch with around 10K miles. Any help is greatly appreciated!!
    Captain James of the SS Impreza has gone down with the ship Drews's Avatar
    Aug 2008
    Davey Jones Locker
    Sounds like the normal chatter.
    Hawk-Eye Alliance #Eleventy,000,000,000|N.E.R.D. Member 20,000
    Stable: 07 GMC 2500HD, 06 LGT, What's left of an 04 STI, 03 WRX, 98 RS, 86 Brat
    Resident Clubdub Debbie Downer. I'd love your ideas if you kept them to yourself. Subarus suck, get a new wife.
    Sep 2011
    Roanoke, Va.
    That's good to know! I was afraid something was wrong.
    Thanks!!
    Registered User naked_dave1's Avatar
    Nov 2011
    Appleton WI
    I have the same exact noise and issue on my 2012 with 9k miles on it. Just started happening about 1,000 miles ago.
    Is there a reason this makes that noise?
    Registered User Chance1218's Avatar
    Mar 2012
    Washington
    Quote Originally Posted by naked_dave1 View Post
    It's a Subaru
    Sep 2011
    Roanoke, Va.
    Upon further research I've learned that it's a noisey throw out bearing. I'm going to try to get it replaced under warranty.
    Registered User GOMEZ's Avatar
    Jul 2011
    San Francisco, CA
    Did you bring it to the dealer? Any other details on the issue? I started noticing a similar clutch/throwout bearing sound upon start-up. It goes away once warmed up.
    '11 WRX 5-door Premium - Satin White Pearl
    http://www.clubwrx.net/forums/builds...-progress.html
    Sep 2011
    Roanoke, Va.
    It's at the dealer now. I'll let you know what they say.
    Sep 2011
    Roanoke, Va.
    Update: The dealer called and said it's a bad throwout bearing and it's being replace under warranty.
    Nov 2011
    Appleton WI
    Quote Originally Posted by Rallye_Ghost View Post
    Made a quick video of my issue. Only happens in the morning and goes away once warmed up and driving for a bit. Did it sound like this?
    Registered User AmateurX's Avatar
    Jul 2009
    Troy, Michigan
    I have a faint whistle when I let my clutch out, when it's cold... I thought it might have been a similar issue as you were having, then I watched the video. Yuck, that sounds terrible. Glad you're getting it fixed.
    Sent from my ADR6300 using Tapatalk 2
    2011 WRX Limited, DGM; full tint, SPT CBE/STS w/ bushings, RA flaps, Enkei PF01s, Pink SuperTones, and ClubWRX.net stickers!
    My Photostream
    about.me
    Sep 2011
    Roanoke, Va.
    Yep! That's what mine sounded like as well.
    Nov 2011
    Appleton WI
    Damn, that sucks. At least I know what it is and can get it fixed under warranty.
    Jul 2011
    San Francisco, CA
    Thanks for the update, ghost. Although my sound is not nearly as bad as what Dave is experiencing, it may get there some day. Is this a wide spread issue? I wonder.
    Sep 2011
    Roanoke, Va.
    It seems like there are alot of people with the same issue. I had to leave my ride another day after it was fixed because the clutch was squeeking so bad. I guess they didn't lube a connection. At least the bearing is new and all should be well today! Now everyone go to your dealers and get your rides fixed by Subaru!!
