Front diffy? tranny? cv axle? help!
Results 1 to 9 of 9
This is a discussion on Front diffy? tranny? cv axle? help! within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; My 02 wrx started making a nice grinding/clunking noise up front. It all started when backing out of a parking ...
    Mar 2012
    Kalispell Montana
    My 02 wrx started making a nice grinding/clunking noise up front. It all started when backing out of a parking spot. Before I parked I noticed nothing, but when I started backing up it made some nasty clunking noises and felt like it was binding up. It did it a little bit in first also but after that it didn't bind up any more, just makes a scraping noise. The noise doesn't stop when its in neutral or when I Have the clutch in. It keeps doing it when the car is off and rolling. Btw its a brand new clutch. Both of my cv axle boots are torn I don't know if that would be anything but they definatley need replaced. Any ideas??
            MainFrame's Avatar
    Austin, TX
    Bad CV joint makes a clicking noise when turning. A worn out center diff will make a grinding noise when turning sharp and feels like the drive-train is binding up. You might need to get the car up on a lift and try turning the wheels independently to see where the problem is.
    Mar 2012
    Kalispell Montana
    Yes ill definatley have to get it off the ground to check it out. The tranny fluid is full and clean so there's a good sign. The noise doesn't change at all depending on how sharp I turn so I'm kinda starting to think maybe its a wheel bearing? Thanks a ton!
            MainFrame's Avatar
    Austin, TX
    Bad wheel bearings make like a humming noise when coasting in a straight line.. I'm dealing with that right now.
    Jul 2012
    Have you figured out this problem yet, or does anyone else know what it is? i have the same exact problem it sounds like and the mechanic doesn't even know where to look.
    Apr 2013
    I see this post is from july, but it just happened to me. Just like you my car was fine prior to me backing up. I deliver pizzas and i was backing out of a customers driveway when i noticed it. My garage i usually go to wont even attempt to tear in to it and see whats up. They said it was transmission related. They also said they were able to duplicate the noise by turning the axle with the wheels off. I am having a second opinion on it tomorrow and will relate that info.
    Quote Originally Posted by subiedoo7 View Post
    Aug 2012
    Tucson, AZ
    I've seen an axle so bad that it binds and grinds whilejust driving. As soon as you get it rolling it was better
    Registered User jamie007's Avatar
    Jun 2003
    Aloha, OR
    Oh no! I just started having this issue with my 09 WRX. When I make a slow sharp turn, either forward or reverse it almost feels like I have a flat tire. Like the front end is fighting the back, something is binding linearly, like every half rotation of the tire... I've always rotated my tires properly, the tires I have on their now only have like 8k miles on them all the same wear. And my clutch (new stock) only has like 12k miles on it. What was the fix? Did you guys need a new center diff?
    Jamie
    2009 WRX Prem Hatch:
    Cobb stage II, Kartboy SS, SPT Catback, Cobb DP, WL Sways, Perrin/AVO Endlinks, Conti DWS
    Previous rides:
    99 Civic Si (RIP), 2004 WRX, 2006 STI Cobb stage II
    Aug 2014
    Zanesville, OH
    If you have torn CV boots, that's likely your culprit! Those boots are there to keep dirt and debris out of the bearing on your CV shafts. What's most likely happened is that you have some junk that's made it's way inside your CV boot and has done some damage to the delicate bearing inside. Any time you find a torn CV boot, it needs to be fixed ASAP or it's just an inevitability that it will cause damage. You probably need to replace the CV joint that holds the bearing assembly or just the whole shaft, which comes with the bearing assembly greased and attached.
    There are plenty of tutorial videos out there about CV shaft work. If you buy a new shaft, you can pretty much take the wheel off and knock out a pin to pull the old shaft and put the new one on the same way.
