Short Throw Shifters -- SPT, Cobb, Kartboy? - Page 3
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 53
This is a discussion on Short Throw Shifters -- SPT, Cobb, Kartboy? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Those crossmember bushings, are they the same as the Whiteline Positive Shift Kit bushings? They look identical...
  1. #31
    Registered User J_Maher_WRX's Avatar
    May 2011
    Newfoundland
    Justin ~ 2011 WRX (WRB Sedan) ~ 275whp/299wtq
    Build Thread Beloww:
    http://www.clubwrx.net/forums/builds...-2011-wrx.html
  3. #32
    Moderator rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    Quote Originally Posted by J_Maher_WRX View Post
    So Tony, it's definitely the WIDE ones and not the Narrow ones I need ccorrect?
    This is what the website says
    "This is the WIDE version. It will fit the shifter if you have the wide pivot point found on the stock shifter. If you have a 97-01 RS or the SPT shortshifter you want the narrow version. If in doubt please ask us!! If you do not know which version you need then email us before ordering.ATTENTION 2008 STI OWNERS!!!!! If you are going to continue to use the STOCK lever then then is the version you need!!! This is due to some lever changes Subaru made for the 2008"
    They are the same thing
    T0ny
    2011 WRX
    2012 FXT
    The Big 2011/2012 Mod Thread
  4. #33
    May 2011
    Newfoundland
    Quote Originally Posted by rage-wrx View Post
    thanks for the heads up Tony! Just to clarify though, in terms of those pivot bushings, WC Lathe Werks states the following:
    •1997-2001 Subaru Impreza 5-Speed:
    Choose the "TiC 5MT Narrow Shifter Pivot Bushings" [TiC_5MT_Pivot_N]
    •2002-2007 Subaru Impreza 5-Speed with the factory short shifter upgrade (the shift lever is gold color and thin):
    •2002+ Subaru Impreza 5-Speed with a stock shifter or Kartboy shifter
    Choose the "TiC 5MT Wide Shifter Pivot Bushings" [TiC_5MT_Pivot_W]
    ALL 2008+ Subaru Impreza 5-Speed with a stock shifter or factory short shifter
    The following picture comes straight from the Subaru website under accessories:
    From that picture, and the "gold" looking lever, it would lead me to believe that I would indeed need the narrow set of bushings, I'm just wondering if the second bolded statement above is what I should be going by or am I just being foolish? haha thanks again
  5. #34
    Aug 2010
    Yonkers/NYC
    Since both websites say that you should get the wide bushings for the all 08+ factory short throws,thats what I'd go with.But to be sure email or call them.
    T0ny
    2011 WRX
    2012 FXT
  6. #35
    May 2011
    Newfoundland
    Ok, I think I'll do that, thanks for the advice tony, really appreciate it, and thanks to all you other guys as well! I'll let you guys know what TiC tells me to hopefully clarify any future confusion for other potential buyers.
  7. #36
    Gold Member lokey's Avatar
    Jan 2011
    Crofton, MD
    Contradiction = definitely call. However, you know my opinion on these. I'd say try the shifter stay bushings ONLY first, and see if that does it for you. They're not THAT hard to install and tighten things up enough for most DDs.
    Greg
    Build Thread
    ProTuned Stage 3ish '11 WRX Ltd HB (SWP) ~ 354 awhp 404 ft-lb tq on E85
    Friends don't let friends drive Mitsubishis.
  8. #37
    May 2011
    Newfoundland
    Yeah, just emailed the guys at TiC, hopefully theyll get back to me by tomorrow. Well I just figured that if I were ordering the Front stay bushing and the Linkage bushings (just received my custom shift knob today along with the Rear Shifter Stay Bushing) I may as well order the Pivot Bushings to save on being nailed with double shipping costs and what not. Do you honestly think it will make that much of a difference to the point it would be TOO precise or firm for a DD?? I just really want the sloppiness of the stock bushings to be gone - I want my shifts to feel very precise. Does anyone have ALL of the bushings, the Front/Rear, the Linkage and the Pivot bushings in conjunction with the SPT Shifter??? If so I would GREATLY APPRECIATE your advice and insight on how the overall feel of the shifting has improved.
  9. #38
    Registered User immenothim's Avatar
    Aug 2009
    Chicago, Illinois, United States
    Hey guys, I ordered a short throw shifter from kartboy that did not fit on my 2007 wrx limited. it was the ss and bushings set for the 02-07 wrx. Anyone know of this issue or do you think i got a bad part?
  10. #39
    Quote Originally Posted by immenothim
    I'm guessing you got the wrong lever. Contact Kartboy. Tom is a great guy and will work with you to resolve any issue.
    TiC is another great vendor.
    Do all the bushings. I have only found one person who didn't like the difference when they've gone through the gears on my car. The only question you should have is whether to get an aftermarket lever as well.
    Sent from my Droid using Tapatalk
    2005 WRX STi (Mods | Virtual Dyno) - Weekend Warrior
    Resident Tuner @ WTF Tuning
  11. #40
    May 2011
    Newfoundland
    Yeah decided to definitely get all the bushings, question though, if I were to get an aftermarket lever, would def be Cobb, would the same pivot bushings fit or would I have to get a different set??
  12. #41
    Jan 2011
    Crofton, MD
    I used the one from the SPT in my Cobb, and it fit perfectly. So yep, same one.
    Greg
    Build Thread
  13. #42
    May 2011
    Newfoundland
    Just as an update for anyone whos following along in this thread, I called TiC today and they confirmed that it is indeed the WIDE Pivot shifter bushings for the 2008+ WRX's. They don't the specific bushing/model year list on their website so hopefully this clues up any confusion. Will be ordering the Kartboy front bushings, the TiC Pivot bushings, TiC linkage bushings, and the Whiteline Trans. Crossmember bushings tonight. I'll let you guys know how I find it when I have them installed.
    Appreciate all your insight and advice guys, thanks again!
  14. #43
    Jan 2011
    Crofton, MD
    Feeding the fire. -- STI Transmission Mount Subaru 5MT Models (inc. 2002-2011 WRX) at RallySportDirect.com ....I mean, you're already there, with the crossmember off. :-)
    Greg
    Build Thread
  15. #44
    Quote Originally Posted by lokey
    Yup. Just a quick jack of the transmission and four 14mm bolts
  16. #45
    Jan 2011
    Crofton, MD
    Enablers. :-)
    Greg
    Build Thread
