whinning coming from rear end of car ? - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 42 of 42
This is a discussion on whinning coming from rear end of car ? within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Originally Posted by mexicanzero i know you can get 75w140($$$) but if your oil isnt fresh then just put some ...
  1. #31
    Apr 2007
    8000' up in Colorado
    Quote Originally Posted by mexicanzero View Post
    i know you can get 75w140($$$) but if your oil isnt fresh then just put some new 80w90 in it and see if it makes any difference, if it does then you can look into thicker stuff
    i would only use the subaru stuff from subaru... but i dont have an sti so i havent read up about whats good and whats not... until you know only use what is guaranteed to work, i wouldnt trust the autozone people to know what works
    First you just mention oil weights and say it's ok to use those, then you say it's only ok to use the Subaru stuff. Which is it?
    Quote Originally Posted by GarrettKoonsman View Post
    Pretty sure your running the wrong oil in your rear diff. you should be running an LSD oil not basic 75W90
    Yes exactly. Only use the Subaru stuff for your diffs and tranny.
    Scott
  3. #32
    Registered User mexicanzero's Avatar
    Oct 2009
    Ottawa Ontario Canada
    if you go back you'll see i realized it was an sti after recommending any oil... and then said to make sure he uses the subaru additive...
    LIVE LOUD, ROCK HARD!!@
    2003 WRX wagon 16g + 6 speed
  4. #33
    Apr 2007
    Ah I didn't catch that. I'm a little slow.....
    I still wouldn't use anything other than the Subaru lubricants, STI or not. Subarus can get funny behaviors if you use difference lubricants.
    Scott
  6. #34
    Registered User GarrettKoonsman's Avatar
    Apr 2009
    CO
    I will say Im running Motul and am extremely pleased with it. But i think its worth saying if your going to make a change away from OEM then be very conscious of whats going on with the car
    2003 Midnight Black Pearl WRX Sedan
    200.7 AWHP Protuned Stage 2 at 5400ft above sea level
    Bugeye Mafia Member #225
    Mods
    Pics
  7. #35
    Oct 2009
    im running extra s so i agree with both of you! however my source dried out so next year the experimentation starts and motul is first on my list
  8. #36
    Registered User v6mx6ls36's Avatar
    Jan 2009
    El Paso Texas
    The rear diff does have an LSD oil in it .
  9. #37
    Oct 2011
    Was this issue ever sorted? I've just fitted an STi gearbox and transmission to my WRX and get the exact same sound as in your video, it's identical.
    Keen to find out what it was.
  10. #38
    Jan 2009
    El Paso Texas
    I found if to be the real wheel bearing . If u fitted the tranny to the car I assume u put the wheel hubs in as well . Check the wheel bearings
  11. #39
    Oct 2011
    Quote Originally Posted by v6mx6ls36 View Post
    Yeah, I fitted R180 hubs as well. However before the hubs were installed I had brandnew bearings fitted.
    Interesting for you that it was a wheel bearing issue, you would think the sound would always be there, not go away when backing off or accelerating.
  12. #40
    Oct 2009
    my whine went away when i did a 6 speed/r180 swap... didnt touch the spindles or the bearings only thing was trans diff and driveshaft
  13. #41
    Oct 2011
    Noise coming from Sti - YouTube
    Was this your car in the video? This is the video I was referring to above, my car sounds exactly the same. Whines when cruising (light throttle), goes away when accelerating or decelerating and it's road speed related (changes tone with speed and sounds the same at any given speed no matter what gear you are in).
  14. #42
    Jan 2009
    El Paso Texas
    Yes it is my car I filmed making the noise
