Shifter bushing whine - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
This is a discussion on Shifter bushing whine within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Ingen Do you think that it would be smart to do this while also doing the shifter ...
  1. #31
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Quote Originally Posted by Ingen View Post
    Do you think that it would be smart to do this while also doing the shifter bushings? I figured I could take everything apart and do all the work at once. Also, how do you feel your car compares to the original noise level at stock with OEM bushings?
    Shifter bushings are installed from underneath the car, so it doesn't really matter what shape the interior is in. You could remove the whole linkage, I suppose, but raising the front up on jack stands gave me all the clearance I needed, you just need to remove a couple crossmembers. Total time was under two hours, and it was first time ever working on my car, so heavy noob factor at play there.
    2007 Outback 3.0R wagon
  3. #32
    Registered User SlapChop's Avatar
    Jun 2012
    I have the same whine but It's only noticable slightly in 1st, and very noticable in 2nd, then it gos away 3rd-5th. Sounds like the whine from a supercharger like somone else said. Is this normal?
  4. #33
    Registered User WRXpa's Avatar
    Jan 2012
    Philly Burbs
    Quote Originally Posted by SlapChop View Post
    Yup, its normal. Don't worry about it
    I have a low Reynolds number
    TP Stage 1 - 2012 WRX Premium 5-Door SWP
    Pics!
  5. #34
    Nov 2011
    Sin City(LV)
    I just installed kartboy SS with front and rear bushings on my 2012 sti hatch and it whines a lot and not quite at all.
  6. #35
    Aug 2011
    Quote Originally Posted by WRXpa View Post
    I lubed the crap out of mine too, and there is definitely a whine in 1st and 2nd...not that I'm complaining though. I like it. I tell people "this is not a quiet car" when they go for their first ride.
    What kind of grease did you use?
    Sent from my Galaxy Nexus using Tapatalk 2
  7. #36
    Jan 2012
    Philly Burbs
    Quote Originally Posted by nuke3ae View Post
    Super late response...white lithium grease from hd.
    Pics!
  8. #37
    Aug 2011
    Ty just bought a tube
  9. #38
    Registered User wearywanderer's Avatar
    Oct 2010
    Ottawa, ON
    I was about to add shifter bushings along with the STI Group N Transmission Mount, the TIC Shift Linkage Bushings and the TIC Wide Shift Lever Pivot Bushings on a 2010 WRX and I'm apprehensive about how the increased NVH might be.
    I did notice thought that KartBoy and Cobb both use 95A durometer polyurethane whereas Perrin's are 88A which I believe means they're softer and I'm guessing less NVH? Has anyone experienced both sets?
    And about the linkage and pivot bushings, will they add to the NVH as well?
