ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums
Go Back   ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums > Tech & Modifying & General Repairs > Transmission & AWD
Transmission & AWD Subarus get their power to the ground through a sophisticated AWD system. Come here to talk about your transmission and "The Beauty of AWD."
Advertise On ClubWRX
Welcome to the ClubWRX Forum - Subaru Impreza WRX and STi Community and Forums.
Welcome to the ClubWRX.net Subaru Impreza Enthusiast Site. ClubWRX.net is a forum based online community for people to hang out, have fun, and gain lot of valuable knowledge about anything related to the WRX. You can learn more about ClubWRX.net here.
You are currently viewing our boards as a guest which gives you limited access to view most discussions, articles and access our other FREE features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload your own photos and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process or your account login, please contact support.
(Registered Users of this site do not see this ad.)
Reply
Thread Tools Rate Thread Display Modes
Old 06-28-2010, 11:16 AM   #1
CNJ1011
what transmissions can i use in a 02 impreza
trying to buy a new manual tranny for a 2002 impreza 2.0 turbo and am wondering what other years have an interchangable transmission
anyone selling a transmission?
CNJ1011 is offline   Reply With Quote
Old 06-28-2010, 07:46 PM   #2
Drews
Captain Drews of the SS Impreza has gone down with the ship
Drews's Avatar
Send a message via AIM to Drews Send a message via MSN to Drews Send a message via Yahoo to Drews
Any of them will fit from 02-07. You just have to make sure you have the right rear differential because the final drive ratios aren't the same for all the different years.
__________________
Hawk-Eye Alliance #Eleventy,000,000,000
Puttin warheads on foreheads...
Drews is offline   Reply With Quote
Old 06-28-2010, 07:57 PM   #3
SeattleJeremy
(the artist formerly known as jeremy96gase)
SeattleJeremy's Avatar
The 5-speed WRX transmissions from 02-05 all have the same final drive and gear ratios as your 02 WRX transmission (and thus will bolt right in).
The 06-07's have a different final drive ratio.
SeattleJeremy is online now   Reply With Quote
Old 06-28-2010, 08:05 PM   #4
Drews
Drews's Avatar
I believe the axles are different as well. Or maybe my mind is still on my 6spd swap :-p
__________________
Old 06-28-2010, 08:07 PM   #5
SeattleJeremy
I thought the axles where different, but the ports where the same?
Edit: According to my favorite online autoparts store the 02-04 5-speeds have the half shafts that mount up to the spindle that goes in to the transmission.
The 05's have the half shaft with the spindle on both ends.
I can't verify the ports on the transmission it self is the same for all years, so until we figure that out CNJ1011 be on the look out for a 03-04 WRX 5-speed with low miles.
Old 06-28-2010, 08:13 PM   #6
Drews
Drews's Avatar
I know that the STI axles are shorter and require the different hubs. Of course doing a 6spd swap is a totally different beast and there about 10 different ways you can do it.
But I believe the 02-03 models have felmale axles. But you can buy adapters. I'm not 100% sure on this though. I'm trying to find the links I have that I used for information on doing a 6spd swap because they have all the information you could ever need on stuff like this. Unfortunately my Afghan internet is slower than molases going uphill with a headwind...
Edit: This is from a 6MT swap thread and has GREAT information on the different years drive trains.
http://forums.nasioc.com/forums/show....php?t=1412230
"Do I need different front axles?
02-early 04 WRXs have female axles and need to use stubs that go inside the tranny. Late 04-07 WRXs use male ended axles that slide inside the front differential so there is no need for stubs. For the female axles, you need axle stubs, circlips, and seals to reuse the WRX axles (check out the seal differences link for part numbers). You can use the stubs from your 5MT. For the male ended axles, they just slide right into place with the correct seals and circlips. 04 STi front axles will work too."
Edit #2: Here are some more helpful links. Again, they are all for a 6MT swap, but seeing as it's still relevant to your question, here ya go.
http://www.i-club.com/forums/showthr...t=wrx+6mt+swap
http://forums.nasioc.com/forums/show....php?t=1201152
http://www.i-club.com/forums/showthread.php?t=12065
__________________
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Similar Threads
Thread Thread Starter Forum Replies Last Post
OFFICIAL 2008 Impreza Information Thread lordcon New Cars/Prototypes Forums 395 12-30-2008 06:50 AM
02 Impreza up pipe MESB Engine Modifications 4 02-27-2008 09:20 AM
02 Impreza wrx-Clock turned off. Need help Starch General Maintenance, Troubleshooting & Accidents. 17 01-13-2008 10:37 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2001-2008 ClubWRX.net
Inactive Reminders By Icora Web Design
