transaxle noises
Results 1 to 13 of 13
This is a discussion on transaxle noises within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; hello everyone i have a 01 impreza rs and i'm having some issues. I can here a clicking noise coming ...
    Mar 2008
    transaxle noises
    hello everyone i have a 01 impreza rs and i'm having some issues. I can here a clicking noise coming from what sounds like underneath the car. It is audible when I let off the gas and coast or engine brake. The clicking is very fast when cruising at higher speeds and slows as the car's speed decreases. It isn't related to engine rpm. As I slow down to a stop, the noise will slowly decrease in repetition until the car is at a dead stop. I also had it running on a lift and could hear a humming coming from what seemed to be the center diff I dont know if the clicking is coming from the center diff as well or perhaps one of the driveshafts. A shop i took it to said they didnt feel comfortable disassembling the center diff and im not so sure i want to get f'ed by the delership quite yet im worried that this may lead to a tranny rebuild any help would be appreciated thanks
    May 2007
    Delaware
    I am having a very similar issue, just got my car back from the dealer last week from a partial tranny rebuild, new clutch..put approx 300mi on her since she been back home. now making a clicking noise when driving..
    Mar 2008
    i had a new clutch installed about 900 miles ago too im not sure if it relates to the noise im hearing
    May 2007
    Delaware
    My noise has seem to have gone away for now. I'll will be looking out for it. Hopefully someone can add more input to this thread..
    Registered User Narsinger's Avatar
    Feb 2008
    snohomish
    tranny noise
    im having the same problem as well i put in a new act clutch and a streetlite flywheel then my tranny went and now after about 300 miles then same noise is back from when i took it in originally, it when i let off the gas at high rpm's it makes a clicking or a noise like something isnt grabbing rite and its being pulled along. PLEASE HELP
    Mar 2008
    Apparently after i had the clutch put in my mechanic didnt tighten the bolts that hold the drive shaft in place and began making a loud thumping sound a few days after i got her back. i had the bolts replaced and the ticking noise i described above began a few days after. im wondering what the loose driveshaft couldve caused and if the noise could be a bad u joint or something any advise would be appreciated i hope i can figure this out i had my snows taken off the other day and had the guy take her for a drive and of course he didnt hear anything it isnt very loud but i would like to fix it before it causes something else
    Registered User 11BC2's Avatar
    Mar 2008
    My shop.
    Try this test:
    Car running, in neutral,foot off of clutch.
    Clicking present?
    If yes, then step on the clutch pedal.
    Does the clicking sound slowly decrease/stop?
    Please provide answers.
    Mar 2008
    the noise is only present when the car is in motion both when the clutch is engaged and disengaged as well as in neutral and will slowly decrease in repetition as the car slows to a stop and isnt present when standing
    Sep 2006
    i would probably check my tires for nails or rocks stuck in the tread..
    Registered User justin.jordan2's Avatar
    Feb 2008
    FAIRFIELD, CALIFORNIA
    I had a similar prob. with my ford ranger clicking noise from the same area. it ended up being a wheel bearing that had worn away, but i then had to replace the whole unit because it had worn the wheel bearing away.
    Feb 2008
    snohomish
    transaxel noise
    so i jacked up the rex to get to the bottom of this problem were all having but cant narrow it down. i can rule out the tranny since it was just rebuild a week ago for $4500 and i checked the drive shaft and u joints they had a small amount of play in them but most definantly not enough to make that terrible noise, but the one thing i did notice was that the noise was coming from the back of the tranny which is the center diff and thats what im putting my money on is wrong. i hope this helps
    Sep 2006
    is it a click, or more of a chatter?
    i had a chatter in my car once, and it ended up just being a pebble stuck between the bushings that go against the bottom of the car.
    Mar 2008
    Hey Narsinger did your problem end up being the center diff because mine makes a humming noise while running off the ground
