adjusting clutch pedal
Results 1 to 15 of 20
This is a discussion on adjusting clutch pedal within the Transmission & AWD forums, part of the Tech & Modifying & General Repairs category; CAUTION: LONG i know this has been brought up many times but i must post again for more new people ...
    CAUTION: LONG
    i know this has been brought up many times but i must post again for more new people to find in searches...
    I bought 05 rex bout month and half ago just broke it in and had the same problem that 90% of new Subaru owners get ( compared to other manuals you have driven or even if this is your first manual you feel the clutch engages too high) By high it is meant that while releasing the clutch it doesnt "grab" untill it is almost fully out right when you feel the spring forcing back at you and your leg is bent very uncomfortably which you feel is making you bog/take longer at lights. So i read and read about how the engage point cannot be adjusted due to the hydraulic clutch untill i found that you can adjust the rod the clutch pedal is connected to that goes into the firewall. This will NOT adjust the way the clutch engages but will make the clutch pedal itself move lower (toward carpet) if you notice the pedal itself stock is about 1/4-1/2" higher than the brake pedal this is the whole problem if you adjust it to even with the brake pedal or slightly lower than, your problems will go away, the clutch will feel so much more "soft" (less push back at you), easier take off, smoother shifting, and less clutch travel.
    So.. your yelling how do i do this... okay lay under your dash look above the gas pedal, push in the clutch, you will see the rod going through the firewall move. There is lock nut there loosen it, than take off the bronze retainer clip which will let you remove the pin. After doing this the silver "U" joint that the pin was going through can now be turned on the threads of the rod. Turn it about 1-2 turns where it moves lower on the threads. Lightly push the clutch in to line the holes up, put pin back in insert clip and tighten the lock nut and give it a try. Hope this helps you out cause it did me. Also important do not over adjust (no more than 2 turns) as it will end up hurting some things.
    BTW: im sorry i dont have pics but im sure you can find some if you do more searches but it is fairly simple, once again good luck and hope it helps someone out
    Sorry to gv27 as this topic was in the sticky. Very sorry just wanted to help out people with my same problem.
    Registered User ShotgunTC88's Avatar
    Nov 2002
    Ky
    Still appreciated that you took the time to post that might have missed it (I did )
    Thanks
    Shotgun
    "Speed Kills......But so do Strokes,...Sign your donar card"
    Registered User TranceDiablo's Avatar
    May 2004
    New York City
    Ahhhh This is exactly what I was looking for. Thanx so much.!
    I thought my clutch was gone cus like u described it was catching at the end of the pedal.
    I will give this a try. it should help me out from what i hear.
    04 STI
    Registered User BrandonWRX's Avatar
    Feb 2003
    Sharon, PA
    Hmmm is this true on the STi too? I agree I have to have my leg bent awkwardly as the clutch is engaging. But wouldnt making the pedal closer to the floor cause it to be engaged at almost the top of the pedal travel?
    MY MODS
    *GET YOUR CLUBWRX KEYRING*
    http://clubwrx.net/forums/showthread.php?s=&threadid=54791&highlight=keychai n
    H4N
    H4N is offline
    Registered User H4N's Avatar
    Nov 2004
    Worcester, Mass
    ya same with STi? it seem to happen with em too... going check it out today.. actully
    Registered User turbo_bxr's Avatar
    Aug 2004
    hamilton,oh
    i did it with only one full turn and now i can shift even faster, and i could shift fast. but still feel like im going to need a clutch....
    well, im glad its helping some out thats why i posted, but umm i have never even seen anything but the body of an sti lol but i would assume it would be the same assembly under there. So hope it works out.
    Registered User shibbyyy's Avatar
    Apr 2008
    Levittown, NY
    amazing! I thought i needed a new clutch because it was so high off the floor and not shifting smoothly...thank you so much! you just saved me quite a bit of money
    Registered User rotorocker's Avatar
    Mar 2008
    Manalapan NJ
    The link to the picture in the manual has a lot more steps then what is mentioned above, including bleeding the system. Is all that necessary? What would be the damage of turning it too far? always partly engaged or disengaged?
    Just remember, capitalization and punctuation marks the difference between, "I just helped my uncle, Jack, off a horse." and, "i just helped my uncle jack off a horse"
    04 Wrx Wagon Cobb Stage 2
    Blobeye Syndicate #026
    Aug 2004
    hamilton,oh
    Quote Originally Posted by rotorocker View Post
    your only moving the pedal, not the entire thing
    Mar 2008
    Manalapan NJ
    curses, now I cant remember which forum the sticky was in that I was referring to but I thought it was just for moving the pedal. I took a quick look at mine and I know the original owner never adjusted it, yet its maybe a few millimeters higher then the brake pedal if that. Yet, there has to be a way to get it to engage lower. Maybe there isn't but most cars let you adjust. I'm just a stupid subaru newbie.
    May 2009
    Short-Clutcher
    When I was researching this clutch adjustment, I thought this would only affect the engagement point. However like someone said in a similar thread, this adjustment reduces pedal travel therefore engagement point is lower, but still high relative to the total travel. This is like a short-shifter mod but instead it's for the clutch travel.
    I did one turn clock-wise facing the firewall. It made a huge difference, I'm quite happy the way it is now.
    Thanks to Time4Flamage for the instructions I used to do this.
    Sep 2004
    Broomfield CO
    I have an 06 and I am just not seeing these adjustment points that you guys have found. I am wondering if anything changed. Anyhow, here are a couple pix. If you guys are able to identify the adjustment points I'd appreciate it, otherwise I am guessing something has changed.
