Alignment basics - Page 20
Page 20 of 20 FirstFirst ... 1011121314151617181920
Results 286 to 297 of 297
This is a discussion on Alignment basics within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Need more alignment talk!!! How often would you recommend getting a alignment done. I saw mention of getting a alignment ...
  1. #286
    Registered User A265's Avatar
    Mar 2009
    in a igloo
    How often would you recommend getting a alignment done. I saw mention of getting a alignment after every time you swap tires, but this seems excessive. So I thought I'd ask the alignment god what he thought and recommends.
  3. #287
    Jul 2001
    Plains of Eastern Montana
    every tire swap- no way; racing autocross that would be a lot of alignments
    every major suspension swap for sure-springs/struts/control arms and the like (no need on swaybars)
    also alignments will sometimes go awry- so if if it's driving funny or you're getting unusual tire wear- have it checked
  4. #288
    Mar 2009
    in a igloo
    Lol would you imagine needing to do a alignment at the event after mounting race tires.
    So if nothing feels or looks wrong would you think it would be safe to do every 2 years? Or would you do it before every autox season?
  6. #289
    Jul 2001
    I typically get it checked before each season (and when I do a suspension change), sometimes the alignment is spot on and nothing needs to be adjusted, but usually there are minor adjustments to be made
  7. #290
    Mar 2009
    in a igloo
    Awesome thanks again for your advice.
  8. #291
    Registered User Peanuts's Avatar
    Feb 2014
    Sydney, Australia
    What is the max camber allowed on the stock camber bolts for a 2011? I've been reading elsewhere that if running coilovers with camber plates, the camber bolts should be set to max.
    Wondering if that's true or not
  9. #292
    Jul 2001
    I've always liked to use the oe eccentric bolts to fine tune the camber (I would think alignment techs would as well). Set the camber plates where you want them and then let the alignment tech fine tune w/ the eccentric bolts. I believe (in the US anyways) that the 11's and + get quite a bit more available neg camber than previous models, iirc some are getting in the -1.7-ish range, which w/ just stock bolts is pretty impressive
  10. #293
    Mar 2009
    in a igloo
    I just got a new alignment done, and got -1.6 on both sides with 100% stock hardware.
    2013 STi.
  11. #294
    Feb 2013
    Anyone got a chance to look at my specs. 2013 wrx with RCE Black Springs. Rear camber came out high but couldnt get much out of the fronts.
  12. #295
    Mar 2009
    in a igloo
    The rear seems on par with what people with lowered 3g WRX have. However you should be able to get a lot more than that up front. I say bring it back and tell them they didn't provide what you asked for or bring it to a other shop.
    That being said they did a great job with the toe
  13. #296
    Feb 2013
    I was going to install some camber bolts up front and have them realign the car. He said he tried to max it out and that is all he could get. Not sure why seeing as I thought I would be able to get more, especially being lowered.
  14. #297
    Mar 2009
    in a igloo
    New alignment with the RCE Blacks and Com-C top hats.
    Seems to have a lot of Cross Caster, heard it was normal?
