Alignment basics - Page 19
Page 19 of 20 FirstFirst ... 91011121314151617181920 LastLast
Results 271 to 285 of 297
This is a discussion on Alignment basics within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; You can't run rear camber bolts on a 08+ unfortunately....
  1. #271
    Registered User A265's Avatar
    Mar 2009
    in a igloo
  3. #272
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Quote Originally Posted by A265 View Post
    Did not know that, but looks like you use bushings instead.
    Whiteline Rear Camber Adjustment Bushings Subaru Models (inc. 2008-2013 WRX / STI) KCA326 at RallySportDirect.com
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  4. #273
    May 2010
    Pittsburgh, PA
    Quote Originally Posted by 06wrx4me View Post
    I've heard horror stories of adjusting those. Supposedly the powerflex variant is a bit easier, but still not easy. Also worthy of note.. The adjustment range is awfully small :-( .
    Sent from my Nexus 7 using Tapatalk 4 Beta
    2011 STi Build Log
  6. #274
    Jul 2001
    Plains of Eastern Montana
    not to mention it's a relatively major undertaking removing the arm and pressing out/in bushings- not like swapping out a bolt on a rear strut
    the camber would have to be really out of whack for me to consider those bushings, and even then there is a likely root cause that should be looked at first (bent arm or the like)
  7. #275
    Apr 2013
    SF
    Big Sky,
    I did my alignment the other day and I got:
    FL: -1.7
    FR: -1.7
    RL: -1.8
    RR: -1.2
    0 toe all around.
    .6* cross camber bugs me, but I only use this mainly as a DD.
    Do you recommend me leaving it as is or should I replace the rear LCAs?
  8. #276
    Jul 2001
    nice job w/ the front for the rear, I'd probably leave it be, if it really bugs you I'd do camber bolts in the rear- a 1/2 degree isn't worth swapping out lateral links imo
  9. #277
    Apr 2013
    SF
    Thanks for your help.
    Camber bolts for rear? How does that work for 13' models?
  10. #278
    Jul 2001
    doesn't work for 13's (or 08-12's either)- in that case definitely leave it as is
  11. #279
    Apr 2013
    SF
    Sorry I didn't state my car's year.
    Thanks for your advice!
  12. #280
    Registered User ThatBroBill's Avatar
    Jun 2013
    Long Valley, NJ
    Hello,
    I drive a 2013 WRX wagon with koni yellows and rce blacks. Do you have any recommendations on improving the #'s? Whiteline Rear Adjustable Control Arms? The car is a DD, Thanks
  13. #281
    Jul 2001
    the cross camber in the rear isn't enough to warrant control arms imo
    I'd say for a daily driver the alignment looks pretty good, all of your toe crosses are good and you have enough camber up front to still carve some decent corners- if you want a little more performance I know the 11+'s can eek out more neg camber up front- in the -1.5+ range from what I've seen
    other than that I'd leave it
  14. #282
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Wouldn't it be ideal to have the camber really close to each other, as opposed to -1.13 and -.87 for the front? Just curious.
    ¯\_(ツ)_/¯
    Kunal - Ordered 2015 DGM WRX
    Photographer | Dancer | Tech Nerd | The Stink-Eye Mob #7
    First Mods: What and what not to do
    2011+ Big Mod Thread
    How to Buy a Used WRX or STI
    Complete USED WRX Buying Checklist
  15. #283
    Nov 2012
    Lansdale, PA
    I would assume those numbers are a little too far part. Just something that crosses my eyes.
    ¯\_(ツ)_/¯
  16. #284
    MAINEiac 11blackSTi's Avatar
    Nov 2012
    Land of the Port. ME
    Quote Originally Posted by kprugbyplaya View Post
    Yes, same with the rear camber. Although on the 3rd gens you can't get much change in the rear camber...although I would think it would be closer than it is. In the fronts like big sky said you should be able to get -1.5ish (I got -1.2 left and right).
  17. #285
    Jul 2001
    for a daily driver a couple tenths of cross camber isn't a biggy; a tenth cross is nice, zero even better, but most shops aren't going to put the time into getting that close and again it's nothing that is going to be overtly noticeable
