Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 241 to 255 of 262
This is a discussion on Alignment basics within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; glad it helped!...
  1. #241
    Jul 2001
    Plains of Eastern Montana
    glad it helped!
  2. #242
    Oct 2012
    Big Sky, THANK YOU for this thread. Have learned a lot and read all thru it.
    I have a 13 STI,750 miles total, I have had it aligned at the dealer and they are willing to adj
    more as needed.
    It has a right pull bias at hwy speeds, really not terrible, and it is better than it was but I feel it could be better.
    The current specs are all in the green and they are:
    Camber FL -0.7 FR -0.4, RL -1.1 RR -1.4
    Castor FL 6.7 FR 6.4 Rear, NA
    Toe FL .01 FR -.01, LR 0.03 RR 0.01
    I know you have said go to -1.0 for street use on front camber and that changing toe will change camber.
    Would you mess with this setup or leave it??
    Thanks for your input and thanks again for this thread.
  3. #243
    Jul 2001
    for a daily driver I'd say your fine, the additional positive caster the newer Imprezas have makes up a little for less neg camber
    w/ the way roads are constructed (high crown) it's not unusual to pull to the right; if it's too bothersome- adding some (even it out w/ the driver's side or even a tenth or two more) neg camber to the passenger side would probably alleviate some of it- that would call for a full alignment, you can't mess w/ camber w/o touching toe
  4. #244
    Oct 2012
    Big Sky. I will try that then. Thanks again for your help.
  5. #245
    Registered User free2be4ever7's Avatar
    Nov 2011
    chicago burbs
    Wow this thread is awesome. Thank you so much big sky and everyone who has contributed. I just learned a lot.
  6. #246
    Resident meany-rator 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    *subscribed*
  7. #247
    Registered User wrx650's Avatar
    Feb 2012
    Cleveland, OH
    Alignment basics
    Next time I get an alignment I will be using this. Thanks!
    -Noah
    2009 Spark Silver Metallic Sedan - Stage 2+
    Build Thread: http://www.clubwrx.net/forums/builds...wrx-sedan.html
  8. #248
    Registered User SubaruWRC's Avatar
    May 2007
    New Orleans
    So I just checking my tires and they outsides of them are all rounded down. Both front and rear... Front is worse. What's up with this? Is this alignment or just my driving? I drive my car hard and autox it. I just installed a rear sway bar so this is a recent change that could be contributing to this wear. What do you think?
    Sent from my Nexus 7 using Tapatalk 2
    STU 17
    Hawk-Eye Alliance #117
    WATCH THIS
  9. #249
    Jul 2001
    most likely driving, not uncommon at all- especially autoxing
    by adding more static neg camber you'll spread that wear a little more across the entire tire, but even w/ aggressive camber numbers the outer edges still go first autoxing
  10. #250
    Registered User kprugbyplaya's Avatar
    Nov 2012
    Lansdale, PA
    Hey,
    I have a quick question and will definitely need advice from you.
    Right now, I have Eibach Lowering Springs on my 11 WRX (sedan); they are currently on my stock struts.
    I am pretty sure my car needs to be re-aligned, since I noticed more wear in my inner front tires. So, due to that, I had the tires rotated.
    I made an appointment at RT2S2 - The R/T Tuning Speed Shop - Homepage for an alignment. I told them stock alignment for right now, until I research on some numbers.
    Here is what I was thinking:
    Since we cant adjust the rear camber without throwing lot of money, I was going to keep that the same (This is what I hear, correct me if I am wrong)
    For the front, I was going to far as -1.5 on both ends and keep the toe 0 and stock caster
    Now my question is, since I am running lowering springs on stock struts, will -1.5 in the front decrease the lifetime of the struts by a lot?
    If so, what do you think is the recommended settings I should have for the front? If not, then why?
    I don't take my car to the track or anything, nor do I always drive it hard. I drive normal, but there are times where I love to take those types of turns and when I do, I want them solid.
    As of right now, I am just trying to meet in the middle where
    1) I do not lose too much tread
    2) decrease strut lifetime
    3) increase handling (doesn't have to be spectacular but noticeable)
    Thanks man. I appreciate your help!
    Best
    Kunal
  11. #251
    Jul 2001
    correct- no factory camber adj in the rear, no cheap way to do it either
    -1.5 might be a little aggressive for street driving (and worrying about wear), I'd probably shoot for -1.0 as a compromise- definitely 0 toe all around- out of whack toe can eat tires in a hurry
    that amount of neg camber shouldn't have any effect on strut life, the springs certainly can however
  12. #252
    Nov 2012
    Lansdale, PA
    Thanks for getting back.
    So I bought the car at 25k miles and I found out Saturday that the car had lowering springs. So the first user already had them installed.
    Assuming he installed them at 10k miles, how many miles can you estimate that the struts will last until?
    My car is currently at 32k
  13. #253
    Jul 2001
    wouldn't fathom a guess, too many variables- I can tell you though that struts are a replacement part and that personally I'd be looking to replace factory struts in the 50k neighborhood regardless, obviously sooner if they degrade sooner
    often you don't realize that the struts are giving up until you replace them
  14. #254
    Nov 2012
    Lansdale, PA
    Sweet. Thanks man. I appreciate your help!
  15. #255
    Nov 2012
    Lansdale, PA
    Last question. I promise! Haha
    Do I need to get camber bolts if I am adjusting to -1 or even -1.1? Because I think the stock ones go up to that point. I mean if the aftermarket bolts are drastically better and efficient, then I will gladly purchase them, but I don't want to buy it if not needed. Thanks for the help again.
