Page 15 of 18 FirstFirst ... 56789101112131415161718 LastLast
Results 211 to 225 of 262
This is a discussion on Alignment basics within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; ah. thanks....
  1. #211
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    ah. thanks.
  2. #212
    Registered User WrRexgoliath's Avatar
    Aug 2009
    Denver, CO
    I used the camber bolts all the way around on tokiko d-specs shocks and rce yellows. I was able to get -1.7 up front and -1.5 rear 0 toe and is wicked awesome!
  3. #213
    Negative Nancy rage-wrx's Avatar
    Aug 2010
    Yonkers/NYC
    I also want to get a custom alignment.But after reading through all the posts I have some questions.I have a 2011 WRX.I have been told that the front camber is adjustable.Does this mean that I do not have to change the lower bolts up front.Also in the rear ,since the camber is not adjustable, do I have to change both the upper & lower bolt?
    Also what is better?Stick to the OEM camber bolts or go aftermarket for the bolts I have to change.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    The Big 2011/2012 Mod Thread
    "Just Leave me alone. I know what I'm doing"-
    Kimi Räikkönen
  4. #214
    Jul 2001
    Plains of Eastern Montana
    all WRX's are front camber adjustable, including the 11
    the oe camber bolt is the upper of the two strut bolts, folks add a second camber bolt in the lower hole (doesn't replace the oe bolt, instead it's used in conjunction w/ it) to add more neg camber
    the 11 has quite a bit more neg camber available than previous models (guys are getting over -2.0 w/ the oe bolts!) so I'd say the oe bolt should be more than sufficient
  5. #215
    Aug 2010
    Yonkers/NYC
    Thank you for the quick response.I was looking through your recommendations for alignment specs for a DD.So you recommend maxing out the front camber, and -1.3 for the rear with zero toe all around.If I max out the front that would be
    -2.0.Would that be too much for a DD?
    and I would have to change just the upper bolts in the rear for OE camber bolts?
    Also I have a 24mm FSB & a 22mm RSB.
    And yes,I am new to this!
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
  6. #216
    Jul 2001
    yes, imo -2.0 would be too much, somewhere in the -1.3 to -1.5 range should be fine, the rear is fixed so you get what you get- as long as the cross (difference between the drivers and passenger side) is close- a 2-3/10th's then I wouldn't worry about
    0 toe front/rear
    just make sure you get a printout before and after and also that you want the numbers as close as possible (they should be able to get front camber within a couple of tenths of each other easily, toe should be very, very close to 0- a couple of 100ths)
  7. #217
    Aug 2010
    Yonkers/NYC
    Thank you ,you have been very helpful.The guy I'm going to does work on rally cars so hopefully he knows what he's doing.
    -Tony
    2011 WRX WRB Stage2
    2012 FXT DGM
    Kimi Räikkönen
  8. #218
    Jul 2001
    Quote Originally Posted by rage-wrx View Post
    you should be golden then
  9. #219
    Registered User A265's Avatar
    Mar 2009
    I'm getting my alignment checked next week and if it's off I'll ask for a custom alignment for the first time.
    This is my DD, I do AutoX a few times a year (I'll probably run 1-3 events before winter). I'd like to be a bit conservative this year. Do you think -1 front camber would be fine? Most of the time, I just drive normally with the exception of a few hard turns, and those few autox events. Of course I'd go for 0 toe all around and closest rear cross camber as possible.
    I have a 2009 WRX, stock suspension.
    I forgot to mention, we do get a lot of snow here in winter so I'll probably need to dial down the negative camber for the winter?
  10. #220
    May 2010
    Pittsburgh, PA
    0 toe front/rear
    If you do very little high way driving compared to local bendy/windy driving, would you still recommend staying around -1.5? My tires on the stock alignment are starting to wear towards the outside inch it appears =/.
    2011 STi Build Log
  11. #221
    Jul 2001
    Quote Originally Posted by A265 View Post
    w/ the 09 -1.0 is about the most your going to get up front, so simply have them max out the front (getting even on both sides)
    no need to dial it back in the winter, -1.0 is not that much camber
    for daily driving I think -1.5 is about as much as you want to go. if you start autoxing or doing track days you can up it knowing that your compromising tire wear; that's where I'd start anyways- you can always dial in more at a later time if you don't think it's enough
    the wear to the outside will be move towards the inside when you up the camber
  12. #222
    Mar 2009
    Thanks a lot for your help, it's greatly appreciated.
  13. #223
    May 2010
    Pittsburgh, PA
    +1. Most of what I've read about alignments has been from you. I appreciate it as well.
    I will aim for 1.5 then up front and see how it goes. I can always use another alignment as an excuse to add other goodies down the road anyhow =).
    2011 STi Build Log
  14. #224
    Registered User kukusz's Avatar
    Dec 2011
    CO
    I've read many pages of this thread, and the only thing I want to confirm is whether getting rear camber bolts for my 2012 WRX would be enough to dial in -1 rear and -1.5 front (on oe bolts since they seem to go to -2 on the 2011-12)?
    2012 WRX
  15. #225
    Jul 2001
    unfortunately the new (08+) Imprezas are unable to use camber bolts- they are no longer strut based in the rear
    in the front you can use them in conjunction w/ the oe eccentric bolts (if you need camber outside of what they provide)
