Alignment basics - Page 14
Page 14 of 20 FirstFirst ... 4567891011121314151617181920 LastLast
Results 196 to 210 of 297
This is a discussion on Alignment basics within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; nice numbers guy definitely did a good job, I'd be dropping him off a 6 pack of something good...
  1. #196
    Jul 2001
    Plains of Eastern Montana
  3. #197
    Nov 2008
    last month I have read maby all of allignment threads about subarus. I ahve 02 JDM wrxwith cusco suspension, c usco camber caster plates. my caster and camber are maxed out from shock heads. I had stock 16" wheels with 1.4F 1.3R cambers, (F and R swaybars are 20mm) and I had awfull understeer. then after installing cusco suspension I had 17" wheels F-2.3 R -1.4 camber , 0 TOE. the car performed well balanced, but with some understeer though.
    now I have made Free caster mode, max camber max caster from plates. I have also installed rear aluminum endlinks and allignment is:
    F-2.5
    R-1.6
    Toe=0 all around.
    looking for track reopen after rebuilding to test settings and whole suspension.
    how do u boys think, didn't I overshoot front camber??? isn't it too much for track use? I think no, but sometimes maby yes. won't I wear inside of tyres faster?
  4. #198
    Jul 2001
    -2.5 is fine, tires should be fine w/ 0 toe- rotate them often and keep and eye on them
  6. #199
    Registered User shadowpr's Avatar
    Jan 2011
    TX, NY
    I just installed an anti-lift kit, new tie rod ends, rear camber adjustment kit, and toe correction control arms in the rear.
    I'm going to try and get my alignment done tomorrow or wednesday.
    Should I ask them for 0 toe all around, and -1.8 (or so) camber all around?
    this is a dd, but i like taking turns a little hard.
    Are there any other settings that I might want to consider?
  7. #200
    Jul 2001
    yes 0 toe f/r, have them max the front neg camber out w/ the oe bolt (you don't mention additional camber bolts or camber plates up front)- this should yield ~ -1.3-ish (give or take a little), have the rear camber set to ~ -1.0
    this should give you pretty good tire wear, while still being able to corner decently
  8. #201
    Jan 2011
    TX, NY
    it's ok to have the rear camber set differently than the front?
  9. #202
    Jul 2001
    yup having a little more neg camber up front vs rear, dials out a little understeer
  10. #203
    Jan 2011
    TX, NY
    ok. thanks.
    between the new bushings, the alignment and new sway bars, I should have a completely different feeling car.
  11. #204
    Jan 2011
    TX, NY
    Before:
    Front l/r Rear l/r
    Camber: -.3, -.8 -1.1/-.8
    toe: .67, 1.13 .59, .45
    After:
    Front l/r Rear l/r
    Camber: -.2, -.6 -1.5/-1
    toe: .01, -.01 -.01, .02
    The guy said he couldn't adjust the front camber at all. I thought it should be able to go a bit lower than that.
    And for the rear, they said they couldn't get my whiteline rear camber adjustments to adjust that much.
    Not sure if I'm happy about that.
  12. #205
    Jul 2001
    well the guy is flat wrong sadly you have to loosen both the upper and lower bolts on the strut and then turn the top eccentric bolt to adj camber
    he doesn't know how to use camber bolts in the rear- you had better #'s in your before than after
    on a positive note, toe numbers look fine
    I'd take it back or try a new shop
    if you go back to the same shop have him read this first (aftermarket camber bolt installation and adjustment)
    Camber Bolt FAQ and Tutorial - NASIOC
    I'd say (sadly) that probably 1 shop in 10 knows how to properly use camber bolts
  13. #206
    Jan 2011
    TX, NY
    yeah. they were nice guys, but I didn't know enough about how teh adjustments should be to explain it to them.
    the numbers aren't bad, but not what i wanted.
    i might just end up waiting several months to get new springs, shocks and camber plates / strut tops.
  14. #207
    Jan 2011
    TX, NY
    I just got new springs and shocks, and some whiteline camber bolts for the front. The ride height is lower now. Should I be trying to get the same numbers as before?
  15. #208
    Jul 2001
    not sure what your #'s were before, but if you have camber bolts up front might as well take advantage of them
    should be able to get in the -1.5 range up front, camber rear is non adj, 0 toe front/rear
  16. #209
    Jan 2011
    TX, NY
    The numbers before I put the new springs/shocks and camber bolts:
    Front l/r Rear l/r
    I also have rear camber adjustment kit. I replaced the stock front camber bolts with teh whiteline ones, but will also bring them with me in case they need to use both to get the camber I want.
    So shoot for -1.5/-1 f/r camber, and 0 toe all around?
  17. #210
    Jul 2001
    the WL bolts shouldn't have replaced your oe camber bolts (upper ones)- they are not the right size, they are meant for the lower hole only up front- get that swapped pronto
    yes -1.5 up front would be a good # to shoot for (you'll need both bolts for that is my guess), if you have the ability to adjust rear camber, then yes -1.0 would be just right
    yes 0 toe f/r
