Alignment basics - Page 11
Page 11 of 20 FirstFirst ... 234567891011121314151617181920 LastLast
Results 151 to 165 of 297
This is a discussion on Alignment basics within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Big Sky WRX as the alk adds ~ .5 degrees of positive caster- yes you have better ...
  1. #151
    Registered User Nick-subiefan's Avatar
    Nov 2007
    Chicago
    as the alk adds ~ .5 degrees of positive caster- yes you have better dynamic (in a turn) camber happening. .5 isn't exactly an eye popping increase so while there is benefit, it's not huge
    the main reason they came up w/ the alk is to remove some anti- lift and some anti-squat that the factory dialed in- this is the opposite of what a lot of people think- w/ an alk you car will lift, squat/dive MORE, not less- HOWEVER w/ these geometries changed you get much better corner exit and corner exit is key to getting around a track or autox course fast
    to the question of more camber up front- yes at some point it would be worth dialing in a few more tenths- you'll see after a few autox's that your outside is wearing faster than your inside (even though you've dialed in more neg camber which should have it wearing the opposite- which if you drove perfectly straight all the time it would)- no need to rush out right now- run few events then consider adding a little more camber up front
    Thanks. I'll drive it like this for a while and check the tire wear and maybe later I will dial as much as neg camber as possible and see the difference then. Anyway I should see improvements over stock set-up. I never Auto-X-ed on anything other then the stock suspension set-up(including all-season tires). It should be a lot better now with the new set-up and RE-O1R tires.
    Thank a lot guys for helping the Subaru community.
    PS: I only hope I will be as knowledgeable as you in any Subaru field so I can help others the same way I've been helped.
  3. #152
    Jul 2001
    Plains of Eastern Montana
    I'd be very surprised that any ALK could net more than a 1/2 to degree of caster- linky?
  4. #153
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    I'll search...
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
  6. #154
    Nov 2006
    Denver Metro Area
    GT Spec Antilift Kit:
    a. Made of aircraft grade 7075 aluminum.
    b. Uses a rubber bushing which is much stiffer than the softer factory rubber ones.
    c. Adds 3.27 degrees of caster.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  7. #155
    Nov 2006
    Denver Metro Area
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  8. #156
    Jul 2001
    I believe that's a typo, .35 degrees is more like it
  9. #157
    Nov 2006
    Denver Metro Area
    Anti-lift Kit FAQ - NASIOC
    That's from unabomber...
    3.27 Degrees of caster
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  10. #158
    Jul 2001
    they are basically the same links- the Toronto site "borrowed" the number from the Unabomber thread- I'm telling you the number is wrong
  11. #159
    Nov 2006
    Denver Metro Area
    Yeah, I understood that was borrowed, but Unabomber is a better source than any canuk (jkjk!)
    I believe you, but I've read that elsewhere as well... so I'm going to debunk this. I emailed GTSpec.
    Kevin
    Moderator
    WRX Gas Mileage FAQ
  12. #160
    Jul 2001
    I pm'd unabomber and told him to correct to it
  13. #161
    Apr 2009
    Bend
    camber plates?
    I'm looking into getting some H&R lowering springs for my 09 WRX. Would i have to get camber plates to be able to get it properly aligned afterward?
  14. #162
    Jul 2001
    no
  15. #163
    Registered User Spencer3636's Avatar
    Apr 2009
    No-Town
    Hmmm went and got my alignment yesterday, they said they could only get my front camber to -0.9 both sides. considering the OEM spec is -1.3 to -0.8 I'm gonna say he didn't try hard enough maybe?
    Also my rear camber is
    Left -2.5 Right -1.7
    That is almost a 1 degree gap I'm going to assume some camber bolts are in order?
    Also what is the Ideal for the Included Angle? OEM says 12.6 to 14.6 how important is this?
    Carpe Diem!
    My 03 Bugeye is cooler than your mom
    Bugeye Mafia #222
  16. #164
    Jul 2001
    cars vary- so it's possible they squeezed it all out (also possible they didn't)- often you see one side where you get more- say -1.3 and the other only -1.0- usually better to even them up (which means reducing camber on one side)
    -2.5 is very high for rear camber- yes good candidates for camber bolts
  17. #165
    Apr 2009
    No-Town
    Thanks for the info, I'm going to run down and get some camber bolts after work. Maybe I'll get some for the front too and see if I can get my front a bit more negative.
    Carpe Diem!
    Bugeye Mafia #222
