A BTW for 04+ owners considering the "H6" uprated rotors
Results 1 to 8 of 8
This is a discussion on A BTW for 04+ owners considering the "H6" uprated rotors within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; You don't need to figure this out w/ the car on jackstands, the caliper and bracket off and a couple ...
    Jul 2001
    Plains of Eastern Montana
    You don't need to figure this out w/ the car on jackstands, the caliper and bracket off and a couple of hours before heading out to a two track event.
    First you need 02/03 rear pads (had this covered) as some genius decided to change the rear pads. Second and this is the part I flubbed up on- you need the 02/03 pad guides/clips- the 04 ones won't work w/ the 02/03 pads. They'll clip to the bracket fine but the pads won't fit.
    On the bright side I've got one rear dust cover drilled and off
    Big Sky
    Aug 2004
    Southern California
    good lookin' out...
    May 2005
    Phillytown, PA
    I was just rereading Project Wagon thread...
    Damn shame I missed this, I made the same mistake.
    Sorry for the thread grave digging.
    Jul 2001
    Quote Originally Posted by wrx wagone
    Hey- your in good company
    May 2005
    Phillytown, PA
    Quote Originally Posted by Big Sky WRX
    I was at about the same spot when I said, "damn, I guess I'm called the Subaru dealer."
    I ending up running over to the local one about a half hour before they closed to buy a whole '02 rear pad set even though I had some hawks at home.
    Oh well, now I have OEM "winter" pads...
    Jul 2001
    Mine was a little worse- I had both brakes off-pads out/regreased, both dust covers drilled and off, rotors on- headed for a track day- then discovered the pads didn't work- nearest dealer 150 miles away- rotors off, old rotors back on, brackets off- old brackets on, pads back in- off to my track day w/ the same setup I had originally.
    May 2005
    Phillytown, PA
    How long after you did the H6 upgrade, did you apt for the 2pot setup? What caused you to make that decision?
    Jul 2001
    I think it was about a year later- I got a deal I couldn't refuse Already had the four pots, so I figured I'd go all out.
    Ofcourse mine was installed the old fashioned way- now Tom at Kartboy has bolt on adapters!
