Project wagon begins! - Page 91
Page 91 of 104 FirstFirst ... 4181828384858687888990919293949596979899100101 ... LastLast
Results 1,351 to 1,365 of 1547
This is a discussion on Project wagon begins! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; send a pic of my link (w/ the measurement)- hopefully that'll do it...
  1. #1351
    Jul 2001
    Plains of Eastern Montana
  3. #1352
    Registered User Pzary3233's Avatar
    Jan 2006
    Tallahassee, FL is home... Memphis, TN for school
    Interesting... I've just got the Whiteline bits, and well the bar is NOT where is should be... I'm going to have to do the boxes....
    2002 PSM WRX <- going back to stock Suspension parts GALORE for sale!
    The Project STX Sedan Build Thread
    Race hard or go home!
  4. #1353
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    wheel spacers
    Big sky on 5mm wheel spacers. My car is very neutral right now with a slight tendency to under steer. I would like to dial out the remaining under steer and saw you mention 5mm front Wheel spacers in another thread.
    Questions:
    Which brand and where to get?
    Do I need longer Wheel Studs?
    Im running 225 45 17's on 17x7 Superleggeras 45-48 ET. I have USDM STi springs on with stock struts. Do you think I will rub?
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
  6. #1354
    Jul 2001
    H&R - they come w/ longer studs (good quality)- 5mm spacer requires longer studs no matter what anyone may say to the contrary- I got mine from here:
    http://www.flatironstuning.com/shop/...l-spacers.aspx
    no chance of rubbing w/ that setup as they are up front and there is mucho room
  7. #1355
    May 2005
    Phillytown, PA
    Actually I wasn't at all impressed with the wheel studs that came with my H&R kit. The knurled end that seats in the hub was quite a bit oversize and I ended up doing a good bit of damage to the studs just to get them in. I instead elected to get a set of ARP wheel studs and am MUCH happier. I ended up using my H&R spacer with them, but I'd use about any 5mm spacer you can get your hands on.
  8. #1356
    Jul 2001
    I wonder if they changed studs, mine were almost identical to the oe ones (save length)?
    the ARP ones are quality no doubt, Nismo also makes a suitable stud (I had the part # somewhere)
    any luck w/ Poltec?
  9. #1357
    Jan 2006
    My H&R Studs were just fine... and as Mike stated like the oem just longer. Not too bad to get them in either, once you find a way that works for you.
  10. #1358
    May 2005
    Phillytown, PA
    any luck w/ Poltec?
    Nothing yet.
    I wonder if H&R changed studs, or if I got a bad batch. They were nowhere near OE quality.
  11. #1359
    Jan 2006
    Weird...
    I am salivating over their lateral links..
    That's no good, I'll have the wheels off the car tomorrow, I'll go take a look and compare.
  12. #1360
    Jul 2001
    found it Nismo stud that purportedly a perfect fit (only longer) 40222-RS035
  13. #1361
    Jun 2006
    Nor Cal
    Sweet thanx!!
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  14. #1362
    Jan 2006
    Hey Mike!
    Looking down on top of them, with the top of the picture being the forward part.
    A look from the "rear" of the car.
  15. #1363
    Registered User AgentH's Avatar
    Feb 2005
    Philadelphia Area
    Pzary3233, is that the WL ALK? Thougth those were STX illegal.
    BigSky, is a wider front track something to pay attention to more for fine tuning than anything else? How would that compare to something like a JDM limited slip up front?
    I run 3mm spacers up front in the winter so I can use my stock wheels w/my 4pot calipers. No problems so far, but I'm definitely running out of threads. And to no surprise, I've never had a lug nut come loose.
    2nd WRX...
    More than meets the eye.
  16. #1364
    Jul 2001
    thanks for the pics- that'll help
    no those are the WL offset bushings- ST* legal interesting- I got a email from WL asking about alternate orientation- the above adds positive caster ~ .5-/75 degrees here's what they had to say:
    "Hi Mike,
    KCA375 can be fitted in any orientation around the clock, but with
    varying outcomes. If fitted with the offset in the horizontal plane (3
    or 9 o'clock), the result will be caster change. If fitted in the
    vertical plane (12 or 6 o'clock) then the result will be a change to
    anti-lift/dive properties.
    Hope that this helps.
    Regards,
    Wojtek"
    at six o'clock you'd have a ALK of sorts- reducing anti-dive/lift IF one already had lots of caster (say STi or maybe from canted plates) it might worth considering the alternate???
    wider track at least w/ 5mm is a very subtle change- having a lsd up front would be a not so subtle change
  17. #1365
    Jan 2006
    So mine are more or less set for more castor...?
