Project wagon begins! - Page 8
Page 8 of 104 FirstFirst 12345678910111213141516171858 ... LastLast
Results 106 to 120 of 1547
This is a discussion on Project wagon begins! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; It doesn't interfere with the function of your struts so it really doesn't "harshen" the ride but it will "stiffin" ...
  1. #106
    Jun 2003
    Bay Area
    It doesn't interfere with the function of your struts so it really doesn't "harshen" the ride but it will "stiffin" the ride. You'll notice it. Only thing gonna really harshen the ride to a real noticeable degree are things like lower profile tires, stiffer springs, coil overs. even strut bars to a degree.
    but I guess it depends on your idea of harsh ride.
    Only real disadvantage is gonna be if you just don't like it. That and in the snow it is a set back. Makes the rear end a bit more prone to step out on you. But as long as you don't go getting like this beast of a bar I really don't think you are gonna unbalance your car,not like it, or have many problems in the snow.
    Stay like....20-22 and you should be solid since our front bars are 20.
  3. #107
    Registered User scottigee's Avatar
    Mar 2004
    Southern Cali
    word. My stock sways are 0.0mm in the front and 0.0mm in the back.
    Can you tell?
    Pushin' a Honda but scoping the Scoobies.
  4. #108
    Mar 2004
    Southern Cali
    Sweet heavenly jeebus...everytime I look at these pictures I shake my head and laugh. I'm lucky I wasn't scraping my side view mirrors
  6. #109
    Jul 2001
    Plains of Eastern Montana
    Re: front aluminum control arms
    Originally posted by Lowball
    Mike,
    Tell more about how you got these in. What did you do about the bushing deal??? How do they feel??? I'm interested in this set up if it really makes a difference in the handling of the car?
    Also, what are your feelings on the 20mm front bar with the 21mm rear bar?
    As you know I'm running the 20mm f wagon and 20mm r sedan bar. All things being equal, will the 21mm rear bar help with body roll as well as help reduce understeer?
    I've been told that my car is very flat in the turns (BMW guy who was following me around the track). I would expect the 21mm bar to further help in this regard.
    LB
    Day to day driving you'll never know you have the aluminum arms up front, start pushing it to 8 or 9/10ths and you'll kow you have them. They are much stiffer than the stamped steel ones and replacing the rear bushing to Grp N ones make it that much stiffer. Stiffness in control arms combats unwanted camber change, which equates to more grip. As a bonus your shedding some unsprung weight as well ~ 1.5 lbs/side.
    If one owned a sedan, to me it's no brainer ~ $300 for the whole kit and kabootle- rear bushing/ball joints, etc. For us "poor" wagon owners it's more expensive- there isn't the # of GC arms out there as there is GD ones, so we pay more. So it becomes a question of whether it's worth it $ wise, that becomes tougher and is different for each person. You do track your car so your going to see more benefit than a strictly street driven car.
    I have seen GC takeoffs for $350-400 w/ all the bits, if a guy can find a good set that would be the way to go.
    The other option is to upgrade just the rear bushings to Group N ones, I did that w/ my sedan before I had a little offcourse excursion. and replaced my bent arm w/ aluminum ones- the bushings alone made a difference.
    The larger rear sway bar, in addition to dialing out some understeer, will decrease body roll some as well. The 21mm rear w/ 20mm front seems to be a very good combo for the wagon.
    scottigee- that look like GP Moto styling!
    Big Sky
  7. #110
    Jun 2003
    Bay Area
    yeah...I'll be doing bushings in the spring. Whole work up. Steering as well.
    I had jdm control arms when I had my civic. same deal there. USDM stamped. JDM solid. lighter. stiffer.
    pisses me off. they bet better suspension. Better head lights. and better motors..errr. At the least they could give us the suspension bits and the headlights.
    Made a big difference for me but I also had a fwd car so the extra strength up there was massively noticeable.
  8. #111
    Jul 2001
    Better brakes too
  9. #112
    Registered User coolblue04's Avatar
    Mar 2003
    near Toledo, OH
    Mike, I see a stoptech BBK in your future... with rear H6 conversion... right?
    Tuned Perfection Autosports
    2005 Sti Widebody
  10. #113
    Registered User Lowball's Avatar
    Oct 2002
    Sac
    Originally posted by Big Sky WRX
    Better brakes too
    I replaced the front control arm bushing with the GroupN STi ones back awhile ago. But the aluminum arms seem to be the next step. You said the bushings were to small. What did you end up doing to get the right bushing installed with the aluminum arms? or am I missing something.
    LB
    Open minds, free powder!
    XXX Santa Cruz boards for life! XXX
  11. #114
    Oct 2002
    Sac
    BBK all the way! I love me ST-40 kit!
  12. #115
    Registered User driggity's Avatar
    Aug 2002
    Renton, WA
    If he gets a BBK that requires 17s he'll be taking a lot of flack from me for being a sellout
    And Mike, weren't you planning on coming out this way soon? Is that still happening?
    Big pimpin' in a Legacy GT Wagon
    R.I.P. WRX Wagon
  13. #116
    Jul 2001
    Funny I posted yesterday- but it's in cyber space now
    Check the tutorial section- I've got two recent additions- one goes through what's needed for a aluminum control arm swap.
    The GC front bushing is 55mm wide, the GG oem one is 61mm- so you need to make up ~ 6mm so the front bushing fits snug in the bracket on the cross member. I found some metric, hardened washers the right size and were ~ 2.5mm thick, by the time I cinched things down they were more then snug in the bracket. Also I discovered that the GC sway links (pillowball) are too long, the GD (WRX/STi) sdan ones fit correectlt- they're cheaper too
    No BBK for me- couldn't bare the flack from driggity . I like 16" rims (even some 15's for rallyx), so I'm going FHI four pots up front w/ DBA 5000's and "H6" DBA 4657 in the rear. I just found out that there are no Ferodo DS2500's in the states for the four pots and won't be until October - so I'm going to give the R4S's a try for daily driving/autox and a set of R4's for the track.
    I don't think I'll be making it to the west coast this year unfortunately, half my vacation I'll be working the Sturgis Rally to help defray costs of my upgrades. I am going to make it to Pacific Raceway- maybe this fall, if not next year for sure.
    Mike
  14. #117
    Aug 2003
    Boyertown, Pa.
    Isn't driggity the guy who bought that other brake upgrade out from under you some time ago? And then rubbed it in? Where does he get off giving you grief about 17's?
    J/k. I'm really enjoying these posts.
  15. #118
    Aug 2002
    Renton, WA
    Not out from under him. The guy offered to sell it to me before Big Sky asked him about it. I may have rubbed it in a little bit though And I was just looking out for his best interests as I knew that he'd want to run 15s at some point. Not to mention saving him money. Especially on brake pads. I'm really quite the saint
    You should let me know when you're coming out to Pacific. I've been a complete failure at making it out to the track this year. Too much other stuff going on. The one event I was sure about (Portland at the end of this month) isn't even going to happen.
    For those just looking at replacing the bushings for the front control arms I'd strongly suggest looking into an Anti lift kit instead. I really wish that I had made that upgrade earlier. Especially for only $150. Just be aware that if you auto-x with an organization that follows the SCCA classifications you'll technically be in a class that you have no chance of being competitive in since it offsets the subframe.
    R.I.P. WRX Wagon
  16. #119
    Jul 2001
    That's the guy alright, w/ the fancy, shmancy AP brake kit that clears 16" wheels!
    The elusive kit, never offered here stateside, that I pursued like Melville's Captain Ahab pursued Moby ****, for over two years- that's the guy OK.
    I will make it to Pacific- hopefully sooner than later. Too bad on PIR- very nice track!
    Mike
  17. #120
    Registered User Roamin'Coyote's Avatar
    Aug 2002
    Chester County, PA
    Mike,
    I just got Ken's update on the GB...so the porterfields are good, or should I be looking for a different pad?? Aggressive street is what I'm looking for. Nice work on the wagon......makes me smile.
    -wYlie
    wagons rule!
