Project wagon begins! - Page 7
Page 7 of 104 FirstFirst 123456789101112131415161757 ... LastLast
Results 91 to 105 of 1547
This is a discussion on Project wagon begins! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; How does the new tranny mount feel? I have one waiting to be installed; just curious what your impressions are. ...
  1. #91
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    How does the new tranny mount feel? I have one waiting to be installed; just curious what your impressions are. Also, did you find any increase in NVH with your new rear diff bushings?
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
  3. #92
    Jul 2001
    Plains of Eastern Montana
    Much better IMO- I notice no increase in NVH. I ran the entire Group N drivetrain/suspension setup in my sedan and never noticed any increase in NVH.
    It's possible I'm "immune" to increase in NVH though?
    Big Sky
  4. #93
    Apr 2003
    Greece, Athens
    Originally posted by jawbrkr
    Well the parts are on order, and I'll let you know what happens in the long run.
    I ´m interested in your answer too.
    I ´m posting from Greece and i had an issue with my 2004 GGA wagon front suspension.
    I had to replace my front control arm and the local dealer gave me the sedan´s GDA aluminium control arm.
    When i noticed the difference in length between them,and told the dealer he told me i could use them but i had to buy the front swaybar+endlinks of the sedan.So i did.
    After 2 months i ended with a destroyed driver´s halfshaft,and axle-hub.The dealer changed them on warranty and i went back to wagon original set-up.
    So i have still in mygarage the sedan´s parts (control arms+swaybar+endlinks).I saw from a friend dealer the part numbers on halfshafts, between sedan-wagon MY04 and there are different.
    I ´m thinking on doing the experiment and placing again the sedan stuff i have + sedan´s halfshafts.
    So if anybody has the same setup to his wagon i would appreciate if he could post his thoughts.
    Some other stuff waiting also!
  6. #94
    Registered User Lowball's Avatar
    Oct 2002
    Sac
    Originally posted by Big Sky WRX
    subaruxtras has some in stock, I see the SPT site just added them too.
    Mike
    Mike,
    I just ordered the bar from Mike at subaruxtras.com. That guy was very nice and helpful. Thanks for the tip.
    Lowball
    Open minds, free powder!
    XXX Santa Cruz boards for life! XXX
  7. #95
    Jul 2001
    Mike's a keeper
    Had a busy weekend of wrenching.
    Got the front aluminum control arms in
  8. #96
    Jul 2001
    AND Group N lateral link bushings and front aluminum "Saab" lateral links
  9. #97
    Jul 2001
    No BBK for me- 16" only (15" for rallyx maybe )- not worth the flack from driggity moving up to 17's
    I will be getting FHI four pots up front, mated w/ DBA 5000's and "H6" 4657's rear. Unfortunately there are no Ferodo DS2500's in the country- so I'll be trying another pad this time around.
    Lowball- look in the tutrial section I have two entires- one part #'s/schematics for the GC arms and one on install front arms in general.
    The front bushings differed by 6mm -55mm bushing pressed into the GC arm, 61mm bushing pressed into the GG arm (essentially 3mm more metal on each side of the bushing) I found some hard washers the right size that were just under 3mm thick. They tightened up perfectly.
    The other "differnce" I discovered was the sway links- I ordered a set of GC pillow links (they're longer than the GD ones). Turns out WRX sedan ones fit better (they're cheaper too ~ $30/pair).
    BTW Gr8 wheels has two full sets of GC arms for sale in Nasioc vendor section (suspension) I think for $450/set. You may be able to talk them down some.
    Mike
  10. #98
    Registered User coolblue04's Avatar
    Mar 2003
    near Toledo, OH
    Looks beautiful, very well thought out.
    -Jacob
    Tuned Perfection Autosports
    2005 Sti Widebody
  11. #99
    Registered User scottigee's Avatar
    Mar 2004
    Southern Cali
    Are aluminum control arms streetable? I thought I heard that bumps and potholes will twist 'em up good. .. .
    Nice install...nice parts!
    Pushin' a Honda but scoping the Scoobies.
  12. #100
    Jul 2001
    Perfectly streetable- these are oem bits. The "old" JDM WRX/STi's came w/ these oem. The WRX sedans (newer GDA's) come w/ these oem around the world (minus NA ). The GDB's (STi sedans), including the USDM model come w/ these oem as well.
    These are the "choice" of arms for rally- they're fully forged and mucho strong (and stiff).
    The aluminum lateral links are also oem in Japan now (and the Saab ) here), my guess is we'll see them oem here on WRX's in the MY06 model.
    Big Sky
  13. #101
    Mar 2004
    Southern Cali
    oh
    well alright then.
    carry on....
  14. #102
    Jul 2001
    oh
    well alright then.
    carry on....
  15. #103
    Oct 2002
    Sac
    Thumbs up front aluminum control arms
    Mike,
    Tell more about how you got these in. What did you do about the bushing deal??? How do they feel??? I'm interested in this set up if it really makes a difference in the handling of the car?
    Also, what are your feelings on the 20mm front bar with the 21mm rear bar?
    As you know I'm running the 20mm f wagon and 20mm r sedan bar. All things being equal, will the 21mm rear bar help with body roll as well as help reduce understeer?
    I've been told that my car is very flat in the turns (BMW guy who was following me around the track). I would expect the 21mm bar to further help in this regard.
    LB
  16. #104
    Mar 2004
    Southern Cali
    Is there a disadvantage to going too think on the sway bars? Besides harsh ride I mean...
  17. #105
    Mar 2003
    near Toledo, OH
    Thicker swaybars would not increase the harshness of the ride.
    2005 Sti Widebody
