Project wagon begins! - Page 4
Page 4 of 104 FirstFirst 123456789101112131454 ... LastLast
Results 46 to 60 of 1547
This is a discussion on Project wagon begins! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I'm getting control arms for my wagon as well.. which control arms did you pick up? GC8 or the GDB ...
  1. #46
    Jun 2004
    Centreville, VA
    I'm getting control arms for my wagon as well.. which control arms did you pick up? GC8 or the GDB ? I don't know if you know but if you pick up the GC8 it'll fit the wagon endlinks fine, but if youre using the GDB, the endlinks are different.
    Nevermind I read the rest of your post.. nice find with the gc arms.
    "Son video games develop better hand eye coordination and make children into better human beings" - Prof. Membrane
  3. #47
    Jul 2001
    Plains of Eastern Montana
    Yeah their GC ones, if going GD, do your hoemwork. Their longer and will definiely impact suspension geometry- I'd also be concerned w/ axle length, effects on cv joints/wheel bearings etc.
    It has been done, but I don't know aht other bits they replaced.
    Big Sky
  4. #48
    Jun 2004
    Centreville, VA
    to my understanding, all i need is sedan endlinks, control arms, swaybar, sedan shocks and springs... if you know of anything else, please let me know. there isn't a lot of material on this subject.
  6. #49
    Registered User coolblue04's Avatar
    Mar 2003
    near Toledo, OH
    Nice looking setup Mike!! Keep us posted on the project as it moves along.
    Tuned Perfection Autosports
    2005 Sti Widebody
  7. #50
    Registered User driggity's Avatar
    Aug 2002
    Renton, WA
    Those things should make the setup work but there could be an issue with using the wagon halfshafts in the long run. The CV joints may have enough "give" to them to make things work correctly but I'm not sure and I haven't heard of anyone running this setup for a long period of time.
    Big pimpin' in a Legacy GT Wagon
    R.I.P. WRX Wagon
  8. #51
    Jun 2004
    Centreville, VA
    Well the parts are on order, and I'll let you know what happens in the long run.
  9. #52
    Jul 2001
    Got my alignment done- most camber I could get out of the drivers side was -0.9 (could get -1.2 on the other side) so settled on -0.9 (l/r), evened up the rear w/ -1.5/side (with some pushing pulling).
    Toe I set to 1mm out/side- front and rear.
    My alignment guy is great to work w/! 0 cross camber, 0 cross toe- he's a perfectionist.
    I'll get ride height tomorrow- eyeballing it, looks pretty close to what it was.
    First autox in the wagon tomorrow
    Big Sky
  10. #53
    Registered User yerrow's Avatar
    May 2004
    atlanta,ga
    pardon me if i'm wrong, but i've always had the alignment done AFTER setting the desired ride height not before. since once you reset the ride height you are also changing your alignment measurements
    i got a '04 wrx wagon and z20 rhd toyota soarer
  11. #54
    afpdl's Avatar
    Sugar Land(houston), TX
    He has struts and springs I dont think he will be changing the ride height, just measuring.
    Alex
  12. #55
    Jul 2001
    Alex is correct, just measuring (which I still haven't done). I can report that after a lengthy autox session (all is right w/ the world again- I'm back in the saddle )
    that the setup is working thus far. Turn in is precise, long sweepers were amazing, slaloms excellent and the car would transition very well. In tighter corners I'm battling some understeer- I think more camber up front ( a degree of caster wouldn't hurt either) would help.
    So far so good. The daily driven ride is very acceptable thus far as well.
    Big Sky
  13. #56
    Jul 2001
    ride heights
    before f/l 387, f/r 392, r/l 378 r/r 379
    after f/l 387, f/r 391, r/l 372, r/r 375
    essentially front unchanged, rear minimal drop 4-6mm
    Big Sky
  14. #57
    Aug 2002
    Renton, WA
    Did you measure to the plastic fender liner or to the fender itself in the rear? If you measured to the fender itself it looks like my car is lower in the rear but about the same in the front (even with the Noltec plates). Assuming that the 02 fenders openings are the same as on your car. I'm surprised that our cars are the same in the front as mine seems to sit a bit high with the plates in there.
    R.I.P. WRX Wagon
  15. #58
    Jul 2001
    Fender itself. Don't know if the wheel arches are the same or not, the ride height specs are the same- 387 +/- 12mm front; 376 +/- 12mm
    You know w/ my 02 I never got the increased ride height w/ the Noltecs (maybe a couple of mm's), so I don't know. I know some were keeping the tapered washer and that would add ~ .5".
    Big Sky
  16. #59
    Aug 2002
    Renton, WA
    +/- 12mm? Geez I didn't realize there was such a huge tolerance there. I wonder how big the range on stock cars actually is.
    R.I.P. WRX Wagon
  17. #60
    Jul 2001
    Yeah I'd be pissed if my heights were all over the place, 1/2" from side to side is significant- actually could be as much as an inch and still be in "spec".
    Big Sky
