Project wagon begins! - Page 13
Page 13 of 104 FirstFirst ... 3456789101112131415161718192021222363 ... LastLast
Results 181 to 195 of 1547
This is a discussion on Project wagon begins! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by coolblue04 What rear brake setup is that? Looks pretty good. It's the FHI two pot rear setup, ...
  1. #181
    Jul 2001
    Plains of Eastern Montana
    Quote Originally Posted by coolblue04
    It's the FHI two pot rear setup, aluminum calipers, rotors are 290X18 vented. It's what the rest of the world gets oem on their WRX's (including the four pot fronts)
    Me likey my RS wheels, ofcourse I know you used the $ from selling those to buy your brake kit
    Big Sky
  3. #182
    Registered User WRXTwiztid's Avatar
    Mar 2004
    "i live with me wife and tree kids" IL
    *subscribed * and glued to my computer chair.
    05' WRB STI
    MODS
    Go raibh tú leathuair ar Neamh
    sula bhfuil a fhios ag an diabhal go bhfuil tú marbh
    May you be a half-hour in Heaven before the devil knows that you're dead.
  4. #183
    Registered User scottigee's Avatar
    Mar 2004
    Southern Cali
    Quote Originally Posted by WRXTwiztid
    I'm living vicariously through Big Sky....
    Pushin' a Honda but scoping the Scoobies.
  6. #184
    Oct 2004
    this thread is a great read
    awesome car big sky
  7. #185
    Aug 2004
    Bay Area, CA
    Quote Originally Posted by scottigee
    Join the club, my wish list for santa is getting pretty long.
  8. #186
    Aug 2004
    Bay Area, CA
    Hey Mike,
    In regards to the control arms, are they the GC8 JDM STi control arms? I found exactly that for $275 bucks. I wanted to check to see if these are the right ones and what exacly I have to do to get them in, if they are.
  9. #187
    Jul 2001
    Quote Originally Posted by ipozestu
    Hey Mike,
    Yup those are the ones . That's a great buy! I've got a detailed thread in the tutorial section on the install. The front bushing is shorter on the GC vs the wagon- so you have to put a washer on each end, the rear, ball joint bolt right up. You'll pillowball style links up front- either sedan oem ones or Poltecs (might be others as well)- I also found that the sedan sway bar puts the links at a better angle, there other guys running the wagon front bar w/ no issues however (they are running the heavier dyty links though).
    Again great buy!
    Mike
  10. #188
    Jul 2001
    time to put the old girl on a diet
    Losing weight w/ your car yields many benefits- it accelerates quicker, it stops quicker, it puts less heat into your brakes, it effectively increases your spring rates and if it it's unsprung weight- it will help your suspension work more efficiently ie keep the rubber to the road.
    The stock weight of the WRX wagon is 3165 lbs- this is with fluids full & spare.
    I've added a few things to my car- front strut brace (titanium ) ~ 2lbs, rear strut brace (aluminum) ~ 3 lbs, lower arm bar ~ 2 lbs; I've added aero mud guards ~ 2 lbs, my rear rotors are larger ~ 4 lbs, interior a boost/egt gauge ~ 1lb, shifter trim and aluminum dead pedal ~ 1 lb, that adds up to ~ 15 lbs which makes 3180
    The easiest weight to shed is gasoline- gas weighs ~ 6 lbs/ gal, at the track I run w/ a half tank so I save ~ 48 lbs, autox I run w/ 1/4 tank the savings are in the 72 lb range.
    The next place to look for easy weight is in the hatch- the spare tire, jack, tool, spare lid save - 35 lbs
    other savings (~62 lbs)
    Floor mats ~ 5lbs
    Roof rails are gone ~ 8 lbs
    JDM bumper beam ~ 15 lbs
    Odyssey batery ~ 15 lbs
    uppipe, downpipe, muffler ~ 15 lbs
    fog lamps ~ 4lbs
    Unsprung weight savings (~40 lbs)
    Volk TE's ~ 20 lbs
    Ray's lug nuts ~ 1 lb
    FHI four pots ~ 4 lbs
    DBA 500 rotors ~ 3 lbs
    aluminum control arms ~ 4 lbs
    aluminum lateral links (f) ~ 2 lbs
    FHI two pots ~ 6 lbs
    At the track I should be ~ 2995 (185 lbs savings) , autox ~ 2971 (209 lbs savings)
    Thanksgiving and Christmas coming ~ + 10 lbs
    Big Sky
  11. #189
    Registered User ClavoWRX's Avatar
    Jun 2002
    With Chiun, Master of Sinanju
    Quote Originally Posted by Big Sky WRX
    Losing weight w/ your car yields many benefits-..........
    .................Thanksgiving and Christmas coming ~ + 10 lbs
    Big Sky
    X 2
    But you forgot the important one. Drop the kids off at the pool before your run.
    Great info.
    Clavo.
    What's the square root of 69 ?.........8 something
  12. #190
    Mar 2004
    Southern Cali
    yeah seriously! Is it worth it?
    Make sure you shave your head and crank your wang before you run!
    Windshield washer fluid is a good opportunity to shed weight
  13. #191
    Jul 2001
    Ahh- yes
  14. #192
    Jun 2002
    Big Sky,
    Have you seen the new brace by GT Spec that replaces the factory underbody " U " brace ? I think it sheds antoher 12 pounds from the front. It's in the vendors section on NABISCO. Its pricey but I'd like your opinion on it.
    Clavo.
  15. #193
    Jul 2001
    I've seen it- several others as well- the jdm market has quite a few to choose from. It looks like it does a good job of bracing, also some cross bracing as well. IIRC it also lets you reuse the factory plastic undertray (important for aero concerns).
    Like you said, the price makes it tough, but it looks like a nice piece.
    I've got a multi page thread over on nasioc on subframes- pretty good discussion, the verdict is still out on performance issues w/o the frame. I'm thinking about running some "tests" at a track day next year- session w/ the subframe, seesion w/o and another w/.
    Big Sky
  16. #194
    San Diego, CA
    Lighten up
    I also take out the head rests excluding the drivers seat during track sessions. I removed the cruise control - never use it. Removed the wear wiper assembly - don't need it, it never rains or snows in San Diego. Some folks remove the tow hook in the rear, mud/rain cover under the engine, sound/fire proofing mat under the hood. Scooby Mods has a post about removing a useless metal pan tucked under the storage compartment of the center console.
  17. #195
    Jul 2001
    Never thought about the head rests (don't have any up front- 04 ), but do have 3 in the rear though.
    I've seen the metal "liner" on the center storage console when I had it out to install my short shifter, looks like it would be a couple of lbs. There are two other metal inserts- one of the driver's side (under the steering column), the other in the passenger side glove box. I took these out in my 02, but at only ~ 1 lb each, probably not worth the effort. I think they serve as knee "braces" in a accident.
    The plastic undertray plays a pretty important aero roll, would be fine to remove for autox, worth keeping for track IMO.
    It all adds up- some guys have very significantly lightened up their cars, but at the obvious expense of comfort ie AC, noise- all sound deadening, etc. If this wasn't my wife's daily driver I'd probably be shedding significantly more .
    Big Sky
