Results 1 to 15 of 25
This is a discussion on Koni Insert Info within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Thought you guys might be interested in the Koni street catalog. The catalog has cool stuff like diagrams and information ...
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Koni strut PDF
    Thought you guys might be interested in the Koni street catalog. The catalog has cool stuff like diagrams and information about the WRX inserts, as well as the rest of the line. Interestingly, it says the WRX inserts are rebuildable. It also says they have services available like custom valving and conversion to double-adjustable. I've already enquired about what services like that cost. I'll let you know when I get the answer.
    www.koni-na.com
    http://www.koni-na.com/pdfcatalogs/KONI2000StUpdt.pdf
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Jul 2001
    Plains of Eastern Montana
    Koni + double adjustable = very nice!
    The only thing I don't car about Koni (or KYB) is that they don't utilize a inverted design- interestingly KYB makes the v7 struts so they obviously have the capability to do it.
    My ultimate strut- 40mm piston, inverted and double adjustable.
    Chris could you put that order in for me?
    Mike
    Jun 2002
    Sure. How much you think those'd run? About $100 a strut? $150?
    1993 Honda CBR600F2
    Jun 2002
    Something like this, perhaps?
    It's an insert - should be really easy to install.
    http://www.koni.com/_racing/_damper_...2817/2817.html
    1993 Honda CBR600F2
    Jul 2001
    Shouldn't be much over $100 should it . Easy install, little tig weld here and there .
    Actually I need to write Leda, I think they did have some double adjustable struts for the WRX (same spring seats), I'm also pretty sure they were fairly beefy.
    Big Sky
    Jul 2001
    here they be:
    Jun 2002
    Koni e-mail answers
    I dunno.....those shafts don't look 40mm inverted.....
    Back on topic, I got an email from Koni answering some questions I had. The catalog kept talking about mating them with lowering springs, hence the first question. Gordon Benson was the guy from Koni answering my questions.
    a) I'm planning to run them with uprated Subaru STi springs that leave the car
    at the same height as stock rather than lowering the car. Will this cause me
    any problems?
    You may need to firm up the insert slightly to work with the firmer springs but otherwise it will not be a problem.
    b) What are the damping rates? How do they compare to stock?
    It's unfortuately not easy to say that the Sports that we have are X% firmer than the factory units. That because, unlike a spring rate which is fairly linear (F=kx) a damping rate is a curve that can be tuned to give the ride and handling that we're looking for. The Sports will be generally firmer than the factory units but are still designed to give the car a good ride as well.
    c) What is the piston size?
    29mm.
    d) I saw on your site that you can do several custom conversions - one of
    them being to convert them to double-adjustable. Is this possible on the
    WRX insert? How much does a service like that cost (ballpark)?
    We can not do that with a insert like that for the WRX. The reason being is that the way the insert is mounted (bolt through bottom) does not leave us with anywhere to put the compression adjuster. We can convert the complete housing into a Koni DA unit though for $530/each. Please note that Cobb Tuning also has us do this for them.
    There are also the 8611 inserts available as well but fabrication must be done by the owner to make the housing a non-sealed unit. Also, I believe the housing is too small in diameter for these inserts. Dimensions and more information on this can be found on our website in the motorsports catalog at
    www.koni-na.com/catalog.html
    If you have any other questions, please let me know. Thanks.
    Gordon
    I sent him another e-mail regarding adjustment and their rebuild service. I'll post that when I get it.
    Chris
    1993 Honda CBR600F2
    Jun 2002
    More emailed answers from Gordon @ Koni (answers in blue again):
    e) The catalog says that the inserts are rebuildable. How much is
    the rebuilding service? Is there a core exchange program?
    To rebuild an insert is $140/each but this should really only be done if the insert is being revalved since the inserts are still readily available. There is currently a 6 week turnaround here which is actually about normal from January to about October. There isn't a core exchange program for rebuilds. For warranty (www.koni-na.com/warranty), we can replace units in advance though.
    f) How many steps of adjustment are there? Or is it infinite?
    There are about two turns of adjustment in the inserts (if I recall correctly). It is infinite to the point that you can go anywhere within the range of adjustment. That said, you're really not going to feel any huge differences in anything under about a quarter turn.
    (that's comparable to 9-positions, boys and girls)
    g) The catalog says that full "firm" is typically about twice as stiff as
    full "soft". Would this be about right for the WRX?
    It's close enough. I don't have the numbers in front of me currently but the full range is quite large. When we've done comparisons between other adjustable shocks out there, our range is much much larger (3-4 times as much). If you have any questions, please let me know. Thanks.
    So rebuilds aren't cheap, but you can get them custom-valved at the same time. NICE! He doesn't specify, but I know that when you get motorcycle suspension rebuilt, they'll put in different valving for little or nothing - the valves are often replaced as part of the rebuild anyway.
    1993 Honda CBR600F2
    Jul 2001
    Good info. Looks like the Koni's are a little beefier than oe 22 vs 29mm, damping sounds like it would work well for the STi offerings.
    Jun 2002
    Part Numbers:
    Front Pair: 8610-1351 Sport
    Rear Pair: 8610-1408 Sport
    1993 Honda CBR600F2
    Jul 2001
    Did you order a set to go w/ your RA springs?
    Big Sky
    Registered User thechickencow's Avatar
    Mar 2002
    West Allis, WI
    Big Sky
    I'm tempted. These would be VERY nice for autox I think.
    Jun 2002
    Big Sky
    Yupper! My daddy bought the front pair for me for my birthday. I had some she-money to buy the rears. They just arrived today! I'm hoping to install them this Saturday. Not sure how long it will take - the insert process is a bit of a wildcard.
    1993 Honda CBR600F2
    Jul 2001
    Lucky you. I read a very good tutorial somewhere (it was kind of an offbeat location unfortuantely), that helps a bunch doesn't it .
    Mike
    Jun 2002
    In the tech reference sticky! It's actually for an Eclipse but it's the same. I'm just not sure how long the hacking and drilling will take.
    1993 Honda CBR600F2
