Please provide Wagon Specific Wheel Info - Page 5
Page 5 of 6 FirstFirst 123456 LastLast
Results 61 to 75 of 88
This is a discussion on Please provide Wagon Specific Wheel Info within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Steve - thanks for the link. Jimbo...
  1. #61
    Jun 2002
    Bay Area
    Jimbo
  3. #62
    Registered User AgSpdWgn's Avatar
    Feb 2003
    Seattle, WA
    Will ES100 in 225/45WR17 fit?
    I just purchased a set of Rota Tarmacs (17x7.5, 48 offset) for my WRX wagon ($430 w/lugs shipped from suby_dude). I am leaning toward the Yokohama ES100s for these wheels. Will the 225/45WR17s fit without rubbing? I’ve read that other tires this size will fit but the ES100s tread is wider than most. Is anyone running either 215/45 or 225/45 ES100 on this size wheel without rubbing? Is there another tire I should consider - must work well in the wet as I live in Seattle.
    Thank you for any input.
    Ken
    2002 Silver WRX Wagon - 5 speed
    Turbo Gauge, Security Upgrade, Mirror, Armrest, Premium Sound Upgrade.
    225/45 17 GS-D3s on Rota Tarmacs!
  4. #63
    Moderator aussieinstlouis's Avatar
    Jun 2002
    S34 47.322 E138 29.131 (WGS84)
    I am only speculating - I run 225/50R16 ES100s on the stock wheels with no probs but when you go to 48mm offset you are closing the gap between the side wall and inside of the fender.
    I reckon you may rub slightly.
    Another wagon guy here in St Louis is running 48mm offset OZ Superleggas in the 18 and he had to remove the fender liner on the rear (but his car does look great!)
    Pace runs 215s on a 17" wheel and has no rubbing. If you were to go to the 215 on the 48mm offset you would be in the same boat as me with stock offset and 225s.
  6. #64
    Registered User RogersWRX's Avatar
    Jan 2003
    Highlands Ranch, CO
    I've also got a (White) 02 Wagon, and I'm running the Eibach Pro-Kit springs, stock struts, Rota Attack's, 225/50/17 Falken Azenis and a Perrin rear sway bar, and I do get quite a bit of rub in the back, especially with passengers.
    I ended up having to roll the rear fenders and still occasionally get slight rub. The rear alignment is set at 0 toe and 1.7 negative camber, and yes I do AutoX it. (1st and 2nd in STX so far)
    There another wagon running the AutoX's and he's got MSW (?) wheels with a 55 offset and has no problem with rubbing. He's also got the $2400 Cobb Tuning stage 2 suspension package...
  7. #65
    Jan 2003
    Highlands Ranch, CO
    here's the pic
  8. #66
    Registered User Teep's Avatar
    Feb 2003
    North Shore, MA
    just call me a guinea pig
    I just picked up a set of STi rims/rubber for my 02 wagon (stock height). I pray they fit w/o any tweaking, if not, I will make them fit w/a camber alignment.
    I'll let you know how they go on!
    -tp
    ps: they are take offs (175miles) which I got from a wrxnet/nabisco head! (read: nice nice delivered deal!)
    The 202 Wagon
    Bugeye Mafia "Silent But Deadly Ass-sasin"
    "Just when I thought I was out... they pull me back in!"
  9. #67
    Feb 2003
    North Shore, MA
    they are on... no rubbing
    The 202 Wagon
  10. #68
    Registered User kTuLu42012's Avatar
    Sep 2003
    North Salem, New York
    White Subarus
    RogersWRX, I was wondering if I could see some more pics of your wagon, i saw the pic of your rims jsut now and im looking at white wheels for my wite wagon. If youd like to mail mesome at kTuLu42012@hotmail.com or send me some to kTuLu42012on AIM, or even jsut post some id apreciate. I want to get ideas for mods to mine.
    Thanks.
    -- Ryan
    04' WRX Wagon Auto
  11. #69
    Jun 2002
    Houston, TX
    Hmm. I just got some Rota Subzero 18 x 7.5 with +48 offset
    I put on Yokohama Parada Spec 2
    SIze 225 40ZR 18
    No rubbing yet, and it looks like there's plenty of clearance.
    Havent lowered my wagon yet though.
    Just FYI
  12. #70
    Registered User Midwestrider's Avatar
    Aug 2003
    OH
    I have a question in reguards to the Prodrive wheels in 18's.
    For reading seems most say to opt for offset of 43mm to 47mm of a 8" wide wheel.
    Looking on Prodrive's website at the following:
    PFF7's 18x8 51mm
    GC-07's 18x8 43mm
    GC-06's 18x8 43mm
    GC-010's 18x8 43mm
    I am curious to know why the GC's come in the 43mm offset vs a 51mm. Is the diffence due to the wheel/spoke design?
    I dont intend to do a big brake upgrade, at most I will opt for the STi 4/2 piston setup. But the brake kit upgrade is a BIG maybe.
    Car in question is a WRX Wagon w/ SPT struts and STi lowerings springs (pink's).
    Tire size looking to run is 225/40/18 *Toyo T1's)
    Anybody shed some like to this?
    "Boost, it's the #2 replacement for displacement"
  13. #71
    Feb 2003
    CA
    Prodrive springs and 225/50/16's
    Hey, is anybody else with a wagon running 225/50/16's on the stock wheels with prodrive springs? Any rubbing issues? The prodrives only lower the car about 1" front and rear. I'm currently planning on going with some 205/55/16's unless I'm pretty sure that there won't be any problems with the wider tires and springs.
    Thanks!
  14. #72
    Jan 2003
    MI
    Re: Prodrive springs and 225/50/16's
    Thanks!
    I have eibach prokits lowers 1.3-1.5. and no rubbing issues.
  15. #73
    Feb 2004
    mid atlantic
    Bringing up an OLD post
    I have read a bunch here, first of all. So please no flames. I am prob. gonna buy this winter set up so I can drive in the snow even faster onmy way to go boarding!
    4 (four) used less then one winter Dunlup SP Winter Sport 3D snow tires 225/45VR17 mounted on ASA JH3 silver 5x100 17x7.5" STi offset rims (rims are 4 winters old). Will fit WRX, Legacy, Forester, Baja, and pre-2005 STi.: $600 for the package.
    And I want to be sure that all will fit well on my 2004 wrx WAGON before I go buy 'em. So will they fit with the sti offset on the wagon, which is bone stock other than my cobb V2 accessport.
    TIA,
    jon
  16. #74
    Registered User gogetr's Avatar
    Dec 2007
    is there any way to tell what offset rims are?
    two of the tires on the set of wheels i got with my wagon are worn on the inside. i dont know if they were on the front or back. tires are 225/45/17's kumho escta(not sure on which though as of right now im about 170 miles from my car and house so i cant check). i think the wheels maybe advan rcII's but again im not sure. they look just like them, but gun metal. as far as suspension... from what i have noticed and was told by the fella i bought it off of is that its all STi goods.
  17. #75
    May 2005
    Phillytown, PA
    Quote Originally Posted by gogetr View Post
    Look on the inside of the wheel.
