Poltec end links with Hotchkis / Cobb rear sway bar …
Results 1 to 6 of 6
This is a discussion on Poltec end links with Hotchkis / Cobb rear sway bar … within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I have read how you need to use the spacers differently when using these bars. After looking at the possible ...
    Apr 2004
    Southeastern PA
    I have read how you need to use the spacers differently when using these bars. After looking at the possible combinations I have installed them as shown below. All seems OK, no noise or clearance issues. The links are nearly vertical. I have the bar at the middle position.
    Mods & Pics
    Apr 2004
    Southeastern PA
    For reference what the stock bar (FHI 20mm in this case) looks like with the Poltecs:
    Poltec end links and FHI 20mm sway bar install
    Mods & Pics
    Jul 2001
    Plains of Eastern Montana
    The Hotchkis/Cobb bars require a link- in mounting- you look good to go
    How do you like the bigger bars?
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by Big Sky WRX
    I just installed my Cobb bar 2 weeks ago.
    I like mine.
    I just sent off for my PolTec's yesterday. Between those and hopefully replacing my crummy tires in a few weeks, I'm hoping for a big gain in handling.
    Bill, I noticed that you're running your bar in the middle setting (or so it says in your mod list). I'm still on the soft setting. I intend to go to the middle when I install my links. Will I feel a big difference?
    Also, do you recommend the Cobb/Hotchkis front bar for daily street use?
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    May 2005
    Phillytown, PA
    Looks good Bill! I guess I'll see how it works this weekend at the AutoX.
    Apr 2004
    Southeastern PA
    Quote Originally Posted by RayfieldsWRX
    I like mine.
    A big difference? I would think so as the stiffness rate jumps from 50% to 90% compared to stock. It is certainly worth a try on your wagon. You can always change it back.
    Quote Originally Posted by wrx wagone
    I think they worked very well.
    Mods & Pics
