Problems after 2015 STi steering rack swap
Results 1 to 4 of 4
This is a discussion on Problems after 2015 STi steering rack swap within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I have a 2010 STi hatch that I just swapped in a 2015 STI steering rack into and now I ...
    Registered User Monk_Knight's Avatar
    Aug 2010
    Colorado
    I have a 2010 STi hatch that I just swapped in a 2015 STI steering rack into and now I have a problem.
    Going around moderately sweeping corners (~40 degrees) it feels like the car abruptly hits the brakes. Often accompanied by more of a grinding or binding type noise in the front. Oddly enough, the issue doesn't seem to occur if the car is being driven hard.
    It was accompanied by a VDC traction slipping light and only occurred when off the throttle. After resetting/recalibrating the steering wheel angle sensor it occurs whether on throttle or off and there is no more slip light. Turning off traction control solves the problem.
    When my mechanic plugged in a diagnostics computer and we did a quick run, the computer was showing that in those corners, some of the wheel speed sensors would read differently from others right when the issue was occurring.
    One time it threw a code 071 for steering wheel angle sensor issues, after we cleared it, it didn't come back.
    Really struggling here... it sure seems like the quicker rack ratio is screwing up the VDC, but it doesn't seem plausible that so many others have done this swap into a GR but randomly mine doesn't like it. The folks over at IWSTI seem to have that point of view as well.
    Help?
    TL;DR: Swapped in 2015 STi Steering Rack, now wheel speed sensors are reading oddly and the car drives strangely.
    When in doubt, just go faster.
    Diary of a Little Red Wagon (build thread): http://www.clubwrx.net/forums/builds...red-wagon.html
    For External Use Only irickchad's Avatar
    Sep 2013
    WV
    Wish I could help, man. Have you checked how the part numbers compare? Maybe it isn't actually compatible?
    I have an STi with an intake and no tune, I never change my oil, and my wheel spacerz are mad tyte.
    Aug 2010
    Colorado
    It's a different part number, but lots of people have done it. There's a good 70+ page thread over on IWSTI with at least a dozen or more that have swapped the 15 rack into their GR with no issues.
    Nov 2014
    Australia, Sydney
    Hi did you end up fixing this issue? I have the exact same issue after installing the 2016 sti rack on my 2012 Wrx. Except no error lights.
