Okay, I bought these springs: Racecomp Engineering Lowering Springs Subaru WRX Wagon 2004-2007 GDF300WAG at RallySportDirect.com
And Tokico HP "Blue" struts.
RSD says "2002-2007 WRX owners will need a conversion to use these springs. The stock WRX shocks are NOT a match for these springs. These will work on the WRX with Tokico D-Spec Struts if 02-03 rear tophats are used. To use with 04-07 rear tophats, a spacer will need to be used."
The front springs fit on the Tokico struts just fine, and the rear ones are the right size on the bottom where they sit on the struts.
Problem is, the rear springs have a smaller diameter on top and they won't match up with my (stock) top hats. How in the hell do I get them to fit?
EDIT: I don't think the information from RSD is accurate
