Tire Pressure Problem/Question
Results 1 to 15 of 19
This is a discussion on Tire Pressure Problem/Question within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Hello everyone! Sorry for such a jumpy post, but I'm trying to figure out what is wrong with my 2014 ...
    something else forever Germz to Japz's Avatar
    Jul 2014
    Herndon Virginia
    Hello everyone! Sorry for such a jumpy post, but I'm trying to figure out what is wrong with my 2014 wrx sedan.
    My tire pressure warning light has come on twice in the last month.
    The first time it came on, I was able to (with the help of a friend) set the PSI back to 33 front and 32 back. Last night the tire pressure warning light came back on. Now I understand that with the naked eye it is difficult to see anything wrong, if it is minor, nor be able to feel it much while driving. But what I'm trying to understand is why is air leaking so easily in the stock summer tires?
    What were the pressure the second time?
    Aug 2012
    Tucson, AZ
    Better question. ..what were each tires pressures the first time and second time. One of the tires has a leak and you need to see which tire is lowest. Usually trips about 6 psi below threshold
    Hawkeye Alliance 520
    Previous cars:
    2010 Mitsubishi Lancer (sold)
    2009 WRX (sold )
    2013 Scion tC (sold)
    2008 Audi A4 (Totaled)
    Photographer/storm chaser
    https://www.facebook.com/kevinrimphoto
    IG - kevinrimcoski
    Jul 2014
    Herndon Virginia
    Sorry for responding so late.
    It's the rear driver side tire that seems to be the only one that is whack with the psi.
    That is also the one that I got a scrape on the rim by turning too fast on a corner.
    I doubt air is leaking since it would be noticeable and you could even hear it.
    I might have my rims and tires inspected when I go get my oil changed in a little bit.
    Thank you both for your responses and help!
    Aug 2012
    Tucson, AZ
    It's actually going to be pretty rare to hear air leaking unless it's an extremely fast leak. Sounds like you may have popped the bead where you scraped. Bump the pressures up and spray it with soapy water or a cleaner. You might see it bubble but you won't hear it
    Previous cars:
    2009 WRX (sold )
    IG - kevinrimcoski
    Registered User Soobvirgin's Avatar
    May 2012
    San Diego
    Quote Originally Posted by Germz to Japz View Post
    I have no idea what you just said.
    Quote Originally Posted by nsibanez View Post
    +1. If you can hear an air leak, it'll be flat - and I mean flat - within a matter of hours at best. A slow puncture you'll only find with soapy water. So if you know which tire is losing pressure now, take the car to a tire shop. They'll locate the puncture for you and tell you whether it's repairable or not.
    Registered User 100plus2Vegas's Avatar
    Mar 2014
    Oceanside,Ca
    My light came on the other day for the first time. One of the tires was down to 20 psi. The rest were just under 30. I aired them all up to 50 and the light went out. I will check again tomorrow.
    14 sedan: Protune: 318AWHP 344ft lbs up pipe, Tial EWG, AEM intake, Cobb AP V3, 3" TBE, Avo FMIC, Turbo Smart bpv, Aem air fuel gauge,Cobb knob,Perrin Pitch Stop mount, SPT front strut tower brace, K-Sport coilovers@1.5" drop. Eibach sways, Perrin Spherical end links, Cusco subframe brace, White Line sway braces, Perrin sub frame bushings.
    07 Duramax LBZ- 26psi,intake, TBE, Diablosport programmer, Edge Insight with EGT, EGR block off, BD exhaust manifold, PPE fuel valve.
    mrd
    mrd is offline
    Registered User mrd's Avatar
    Nov 2010
    Livermore,CA
    I think that all 4 should be 35 on 2011+. 50 is to much.
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Weather can also affect tire pressure in alloy wheels.
    Extreme hot and cold can throw the pressure off.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    May 2012
    San Diego
    Quote Originally Posted by 100plus2Vegas View Post
    50psi? Please tell me you're not going to drive on them at that pressure
            MainFrame's Avatar
    Austin, TX
    Registered User Infamouszoltan's Avatar
    Jun 2014
    Salt Lake City, UT
    50?!
    I do 40psi and that sometimes scares me!
    When did we stop being who we want to be, and start being the person the world told us to be...
    Stink Eye Mob #801
    Instagram: Infamouszoltan
    InfamousZoltanSTi
    Aug 2012
    Tucson, AZ
    Ya 50 is way too much. I just go a few above factory specs (33,32) I have them at 35 right now just because they're new tires but they will be at 38,37
    Previous cars:
    2009 WRX (sold )
    IG - kevinrimcoski
    Jul 2014
    Herndon Virginia
    Hey everyone!
    Sorry for such a late reply.
    So I have a 2014 WRX Limited Sedan and it says that I should have 33 psi in the front and 32 psi in the back.
    My TPMS keeps going on every second week or so. I check the pressure in the tires, and it is always the rear tire on the driver's side that is the one requiring air. I know about a month ago or so I drove through construction on my way home and there was a sharp bump against that tire. Is it possible there is a minor air leak?
    I'm very worried since I have only had this car for a few months and already there is another problem to go over and to fix.
    ¯\_(ツ)_/¯ Rambo's Avatar
    Oct 2010
    Portland, OR
    Hey everyone!
    Getting an air leak in a tire can happen to any car, regardless of age or make. Have a tire shop check it out. Our local tire chains will do that sort of thing for free. Not worth worrying over, tire punctures/leaks happen.
    2007 Outback 3.0R wagon
