Bad strut advice - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 26 of 26
This is a discussion on Bad strut advice within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; Originally Posted by Mitch08WRX Thanks for the help. I would love to buy the blacks but I can't be spending ...
    Oct 2005
    Late Devonian
    Quote Originally Posted by Mitch08WRX View Post
    Thanks for the help. I would love to buy the blacks but I can't be spending that money right now unfortunately. I know it will end up biting me in the end, should say screw it and just buy coil overs. Anyways, If I can find some used struts that would be perfect, otherwise I'm going to buy just 2 fronts. Could I get away with the 2009 WRX struts on my 2008? Should I just replace the defective strut only with OEM?
    Only buy OEM used. I think so on 2009 but am not sure at all. Just find out if they are the same part number or call a dealer parts department to ask.
    If you want to replace them to "OEM" 08 2008 Subaru Impreza Strut Assembly - Suspension - KYB, Front Left, Front Right, Rear - PartsGeek
    Registered User Mitch08WRX's Avatar
    Jul 2013
    GR, MI
    Alright I will look to find a used set if I can. If not, do I buy both front's? (rather than have one strut different than all the others) from partsgeek. I don't really want to take a rather long period of time to find a set of used struts if I don't have too. I don't mind buying new off of partsgeek (in which you linked me) for a new passenger and driver side front strut. Honestly, I thought it was going to cost more than $190 for a pair, doing labor myself. Thanks.
    Oct 2005
    Late Devonian
    Yes, do for sure get both.
  6. #19
    Jul 2013
    GR, MI
    Hey guys, not sure if I can bring my thread back from the dead or not.. but I need more advice. As stated previously in this thread, I had a FRONT (driver side) that was lower than my passenger side, on my 2008 WRX AFTER (not sure about prior) installing the Eibach Pro Kit. Make a long story short, after I blew the strut on my driver side, I bought 2 brand new struts and swapped the spring's (to confirm that I did not have a bad or weak spring). After swapping the passenger-to-driver side spring and visa versa, the car sat normal from what it appeared. I thought the problem was magically fixed, apparently not. So now I still have the same issue, my front driver side is STILL significantly lower than my front passenger side. What else could this be? I am completely lost on where to go with this.. what else would result in the height? I really don't want to buy a set of new struts again haha. Thanks for any input!
    Mitch
  7. #20
    2009 WRX Sedan Blammo's Avatar
    Dec 2012
    British Columbia, Canada
    I don't know man. I am a total noob and no mechanical genius.
    I have much to learn about the suspension do's and dont's with WRX and/or STi but I feel you are just throwing away money changing out OEM struts whether you get them for $5 or $500.
    The OEM struts on WRX are maxed out in terms of what they can provide for you with the stock springs. That much I know and have read. When you introduce the aftermarket spring to the stock strut its just NO GOOD. Why even try? Doesn't matter if you buy RCE, Swift, or Eibach etc. Just because some label or ad says they will work with OEM struts, that does NOT mean they will work WELL or that they wont harm your OEM equipment.
    Also, do NOT go buying 2009 suspension parts to put into the 08. From my understanding, the 09 setup is somewhat different from the 08. Of course, im NO expert and I could be misinformed but I have read that Subaru made changes to the 09 suspension from 08. Of course, due diligence on your part may prove im wrong.
    Do yourself a favor and buy a good strong set of aftermarket struts bro. You won't regret the higher investment. You already paid for Eibachs...may as well support them with a decent strut so everything will be harmonious for you and your subie!
    I hope you get it figured out.
  8. #21
    Jul 2013
    GR, MI
    Yeah I know what you mean, thanks for the reply regardless. I said I couldn't "comfortably" afford a set of 4 struts right at the moment and that's why I didn't get them. Honestly just looking for a solution, the car will be going down the road hopefully this time next year once I'm out of school and I plan on getting an STI. I know now to just but coilovers, higher cost but appear to be worth it in the long run.
  9. #22
    Oct 2005
    Late Devonian
    How did the tophats look? Are you sure there were no missing parts? It has to be resolved. Either the top hat is fubbered, the strut body perch is bent, or there is a control arm issue. I'd suggest taking it to an alignment shope and having them look it over.
  10. #23
    Jul 2013
    GR, MI
    Top hats looked good, no missing pieces. Everything was normal when I swapped the springs and put new front struts on at first. Drove it around the block, felt nice and firm. Look 2 days later and still, the same issue, the driver side was lower. So it's obviously not a bad spring and how can it I from being good, back to bad..? I don't understand. I know a friend who has done alignments for the past 5 years, he had a couple other people look at it and they couldn't find anything either. So I had it re-aligned and what not again a couple days ago. Out of ideas, honestly. I have took the strut assembly out probably 6-7 times after fully installing them to try and correct the issue, nothing. I can have them in and out in under 10 min, I'm quite good at it now! lol. Thanks for the reply.
  11. #24
    Oct 2005
    Late Devonian
    OK, go park it somewhere level - really dead level and accurately measure it. What is the difference?
    The more I think about it, the control arm isn't involved really. It is just between the spring, the strut body, and the tophat. Did you leave the springs swapped?
  12. #25
    Jul 2013
    GR, MI
    I took some pictures of the measurements and differences, in which I will provide below this post. To answer your question, the difference is even larger than I thought, a little under 1/2". The springs are swapped currently, I BELIEVE I even swapped the tophat's over aswell.. Obviously, same issue. Anways, take a look at the pictures if you wish. Thanks!
  13. #26
    Jul 2013
    GR, MI
    Front Passenger Side (Good Side): Curvature is perfect.
    Front Driver Side (Bad Side): Notice how the curvature suffers.
