Help!!! WRX gone mad!!!
Results 1 to 6 of 6
This is a discussion on Help!!! WRX gone mad!!! within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; So I've had my 02 wrx wagon for about 2 weeks. I bought it completely stock with 140,000 miles, the ...
    Jul 2014
    Overland Park, kansas
    So I've had my 02 wrx wagon for about 2 weeks. I bought it completely stock with 140,000 miles, the only things I've done to it are a Snorkus and muffler delete. Me and my friends all like to drive our cars hard. However I have noticed that my WRX under steers terribly even with good performance tires on it. Then if I'm going around a turn and hit a bump or have to swerve hard and fast the rear end looses its mind and I find myself 4 wheel sliding all over the road. What will correct this best besides an alignment and tires?
    Make fun of my wagon now...I'll be happy to help you move for a fee
    Registered User Aaronw9's Avatar
    Oct 2012
    Seattle
    Lowering springs or coilovers combined with some sway bars, endlinks and an alignment.
    Dec 2009
    rockville md
    Lowering spring will not fix it, it will lower you center of gravity and give you a ****ty ride with 140k on the shocks, best is to replace it all if you are actually ready for a handling car. And yes a sway bar and endlinks will fic it
    2010 Wrx Satin White Premium, TurboXs TBE, AP stage 2
    Jul 2014
    Thanks you guys, are the apexi n1 coilovers any good in your opinions? Also, should I run a larger sway bar in the front or the rear to help correct the problem?
    Sep 2005
    I didn't like the n1 coils much... high rate (275lb) springs with koni yellows were the best I ever had.
    Get yourself a 24mm front sway, no larger than 20mm rear sway, and close to -1.5 to -2deg front camber with ZERO toe and the car should be pretty sticky.
            MainFrame's Avatar
    Austin, TX
    What's your budget? Being 12 years old virtually everything in the suspension is worn out by now. Recommendations could span from about $600 to $10,000. Without knowing how much you have set aside to spend on fixing it up it's hard to point you in the right direction.
