Multiple Wheel Size?
Results 1 to 7 of 7
This is a discussion on Multiple Wheel Size? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; I just bought a set of used wheels and tires for the car. The new size is 18x8 +35 offset. ...
    Registered User SubiesaurusWRX's Avatar
    Sep 2013
    Colonia
    I just bought a set of used wheels and tires for the car. The new size is 18x8 +35 offset. My stock back tires are bald and definetly not safe. My question is can i run my new 18x8 with tires on the back for a short period, along with my stock 17x8 in the front. Only reason im doing this is because the profile of the new tires is a bit to much and i know i will rub the front splash guard when i turn. This was a rookie mistake because i never bothered to look at the tire size.
    2011 WRB WRX: DW 850 cc injectors. FMS tmic. Custom SRI. GT spec header. Maddad Turboback. Tial mv-s ewg. Perrin Recirc Valve. Grimmspeed ebcs, crank pulley, and up-pipe. Cobb AP w/ custom tune. ACT HD clutch w/ lightweight flywheel. StopTech Club Kit ( front). Whiteline 3-pt adj. sway bars f/r. Perrin front endlinks. Drag DR31 wheels 18x9 +15 offset. Nitto NeoGENS UHP all-seasons. Ultra Racing Rear Strut Bar.
    Village Idiot McBill's Avatar
    Sep 2013
    Buckeye State
    Absolutely not. Do not run two different tire sizes between front and back on ANY awd car. Even the slightest difference in circumference between the tires is damaging to the differentials.
    Billy
    2009 Ducati Monster 1100
    2008 Legacy 3.0R - SOLD
    2011 WRB WRX Sedan - SOLD
    Stink-Eye Mob #696
    Facebook
    Sep 2013
    Colonia
    I have 235/50/18 mounted on all four now. What if i use the 235/50/18's on the back and get 235/40/18's for the front. Would that still pose an issue. My problem is i bought these wheel from craigslist and i pretty much used my extra funds on this set. I made a dumb assumption thinking they would just fit. If run the same size wheel all the way around but run the 235/40's up front and 235/50's in the rear would that be an issue?
    Sep 2013
    Buckeye State
    Quote Originally Posted by SubiesaurusWRX View Post
    Yes that would still, definitely, be an issue. You shouldn't even run the same tires on all 4 wheels in which, say for example, the two front wheels had more than 2/32nds of an inch of difference in tread wear than the rears do. If that doesn't tell you how sensitive it is then I'm not sure what will. You NEED to be running the same tire size on all 4 wheels no matter what. So you need to either run the tires you bought, which it sounds like you will not be able to, or you need to buy a full set of different, preferably brand new tires all around.
    I would suggest selling these tires and getting new ones before you put the new wheels on the car. And be sure to do some research and get tires that will fit this time. We all make mistakes, but it's our jobs to learn from these mistakes in that we don't make them again. Either way, good thing you checked up on here before you decided to slap those new shoes on!
    Billy
    Stink-Eye Mob #696
    Facebook
    Registered User subypete's Avatar
    Jan 2008
    Forsyth, IL
    Looks like there is a fairly significant difference in the circumference of the two tires. I would not run them together... just asking for center differential problems.
Name:	2014-07-21 09-09-11_Tire Dimensions Made Simple - Discount Tire.jpg
    2002 OBP WRX - Stage II - "Black Betty"
    1987 Subaru GL Wagon - Stock - "Mr. Ratburn" - SOLD
    Sep 2013
    Colonia
    Well its been decided. Pretty much better off buying new tires. I have the wheels up for sale anyway up on central new jersey craigslist. So the last thing i would need is for me to buy the tires and then someone gives me an offer. That would suck so bad. Another 400-500$ gone.
    zax
    zax is offline
    Super Modulator zax's Avatar
    Nov 2008
    Neverland Ranch, Maryland
    That offset is out of the recommended range for your WRX
    Zax's Shaggin' Wagon (SOLD)
    Facebook me here
