Enkei EKM3, which tires?
Results 1 to 7 of 7
This is a discussion on Enkei EKM3, which tires? within the Suspension & Wheels forums, part of the Tech & Modifying & General Repairs category; hey guys, today my rims arrived and I have no idea which tires should I buy. Rims description: Brand Enkei ...
    Jun 2014
    Maine
    Rims description:
    Brand Enkei
    Model EKM3
    Item Weight 25 pounds
    Product Dimensions 7 x 17 x 17 inches
    Exterior Gunmetal
    Manufacturer Part Number 442-770-8045GM
    OEM Part Number 442-770-8045GM
    Construction 1-piece
    Rim Diameter 17 inches
    Rim Width 7 inches
    Bolt Pattern (Number of Holes) 5
    Bolt Pattern (Pitch Circle Diameter) 100 millimeters
    Offset 45 millimeters
    Backspace 5.77 inches
    Bore Diameter 72.60 millimeters
    Would appreciate help with this!
    Thank you
    Ed
    Jan 2012
    New Jersey
    Whats your price range? Are you looking for all season or summer?
    CFLip2x 2012 WRB WRX Build
    Jun 2014
    Maine
    Summer tires, and price range... like 300 for a set of four? I'm about to go to college lol so budget isn't too high.
    Was mostly wondering what size etc so it fits in nicely without any problems.
  5. #4
    Jun 2013
    Danbury, CT
    www.tirerack.com, even if just for information.
    They recommend 225/45/17 for your car (04 WRX wagon), but recommend an offset of 48 or larger to prevent rubbing on the fender lip liner.
    You may need to stay with 215/45/15 with wheels with a 45 mm offset.
  6. #5
    Palmyra, NJ
    They are pretty narrow wheels. 3mm won't make too much difference. A 225/45/17 tire should be perfectly fine.
  7. #6
    Apr 2004
    Southeastern PA
    Quote Originally Posted by Ed Edd n Eddy View Post
    You will not get a quality tire for $300 for 4. Figure closer to $600 or more. Seeing as how they are the only thing that keeps you safely on the road, this is one component not to skimp out on. I have a set of OZ Superleggeras (now my winter wheels) in 17" x 7" and ran 225/17/45 the entire time I've had my 2004 WRX bought new. Would not go any wider than 225.
    Edit: just looked at Consumer Reports UHP Summer tire ratings. There is one inexpensive tire they seem OK with. No doubt a Chinese made knock off Michelin Pilot Super Sport / Continental Extreme Contact DW. I'd still be wary spending so little on a UHP tire.
    The size tested were 225/40/18. A 225/45/17 will be cheaper than the prices listed.
    Mods & Pics
  8. #7
    Jun 2013
    Danbury, CT
    The width of the wheel affects the width of the corners of the tread?
    If Sasquatch ran 225/45/17 tires on a 17 x wheel with a 45 mm offset on an '04 without rubbing, that's good. Go for it.
    http://www.tirerack.com/tires/tires....omCompare1=yes
    Probably not bad for the price.
